425 Engine Swap idea
/ 425 Engine Swap idea #21
45 degrees and lower with the Robin, and my prayer life kicks into auto-pilot!
Once I get it started, I would say it is a pretty decent engine (gas consumption, power, torque), and after running a while, when I shut it off, it does not seem to be quite so "fridged".
But that initial start, it is very hard on the starter and the battery!
Btw, I have the 22hp.
/ 425 Engine Swap idea #22
I also have a 422 with Robin engine and it starts pretty easily at 40 + degrees, even at our recent 20 degree days and teen nights it has started without any problem.
/ 425 Engine Swap idea #23
That is different from my experience. I have trouble starting below about 45 degrees. I am not sure of the exact temperature. I have put Mobil 15W50 synthetic oil in the hydraulics. I suspect that makes it worse than the original 5W30. I always park my PT in a heated garage. The PT does climb hills better when hot with the 15W50 and that is why I use it.
/ 425 Engine Swap idea #24
I have the original 5-30 oil in the hydraulic system , the original battery(8 years old) and my garage where I keep it is unheated. Today it was 32 degrees and it started first attempt.when it gets down below 20 I quite often put a magnetic heater on the oil tank.
I took it out and pushed some snow off our driveway and then took a ride up over the hill to see if I could see any bear or deer tracks as we have about 4 inches of snow on the ground now.
/ 425 Engine Swap idea #25
My Robin 25hp doesn't like to start when it's cold, even with the free starter upgrade. Much below 50 and it may need help. I suspect it still doesn't spin fast enough for the magneto to make a good spark. I use a magnetic block heater on the hydraulic oil tank and sometimes still need jumper cables. It would be nice if the small engine manufacturers would move their ignition systems out of the 19th century.
My comment about the diesel wasn't entirely fantasy. Google "Punsun Diesel" for a Chinese air-cooled V-Twin that looks like it might fit. It's around 750cc/20hp (depending on which advertiser you believe), but there have been press releases promising a new version closer to 1000ccs. I kinda doubt we'll ever get it in this country, and then there's the legendary Chinese quality issue, but it sure sounds good.
/ 425 Engine Swap idea #26
Ernemats,
Could you give us a run through on how you go about starting yours?
The throttle and choke position, how long (seconds) do you hold in cranking position before it starts?
Do you have to keep cranking, even if it sounds like it has ignited, but if you (I, in my case) stop, it dies.
Anyone else who wants to give there starting sequence would be appreciated. Maybe we can see a pattern of what is best, good, or worse.
/ 425 Engine Swap idea #27
As suggested, I Googled Punsun Diesel. One of the hits I got led to this engine. I don't think it is a Punsun, but it does look interesting.
Another hit led to this photo, which I thought was a hoot. That's a B&S/Daihatsu engine stuffed into a Harley Softail. JD freaks are everywhere. :D :D :D
/ 425 Engine Swap idea #29
That's the Punsun, or at least one of it's clones. Variations of that same ad copy and a handful of photos show up on dozens of sites. I'm pretty sure they don't pass requirements for import into the USA, but they seem to be somewhat popular in Australia for generators. I think it's intended to be a drop-in replacement for various gasoline v-twins.
/ 425 Engine Swap idea #30
For our Kohler (or any 4 cycle gas engine we have, for that matter) we do this:
Full choke.
Full throttle.
Turn the key to crank until it fires up or 10 seconds, which ever comes first.
If it doesn't fire, stop cranking so you do not cook the starter. Let it rest for 30 seconds and try again. If it doesn't work on the third or fourth try, get out the starter fluid and go that route. Give in one 3 second blast in the air cleaner and repeat the above procedure. If it won't fire on starting fluid there is a spark problem. If it fires and dies, there are fuel problems, like filter plugged, ice, etc....
If it fires, release the key to the run position and decrease the throttle to 3/4.
Decrease the choke until it sputters, then increase choke a bit. Monitor the sound of the engine while it warms up. Keep adjusting the choke until you no longer need it. At zero degrees, that can be 5 - 10 minutes for us.
Keep you battery fully charged. We keep a 1/2 amp charger on ours all the time, winter or summer, because it can be weeks between uses.
I also put Stabil in our fuel during the winter and we have a clear fuel filter.
I can honestly say that in the 7 years we have had our PT425 with the Kohler engine that it only failed to start once, due to the original battery croaking. I have used starting fluid on it a few times when the temps were well below zero, but less than half a dozen times in those 7 years. I have never pulled the spark plugs to inspect them. I have changed the air filter and pre-filter foam last year. I change the engine oil every year. We use Mobil1 since the first oil change. We have about 350 hours on it.
I beat the snot out of it yesterday pulling firewood logs out of the woods for 5 hours. I probably shut it down and started it 50 times as I hopped off and on over and over. I am really impressed with the Kohler's durability and cold weather starting. Let's see how I feel in another year, and so on. :)
Great Dane Van Trailer (A61307)
Great Dane Van...
2011 Ford F-350 Service Truck, VIN # 1FDRF3GT8BEA38908 (A61165)
2011 Ford F-350...
2019 John Deere R-4038 (A61307)
2019 John Deere...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
TRI PAC EVOLUTION APU (A60736)
TRI PAC EVOLUTION...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
