414 Inter Hydraulic Problem
/ 414 Inter Hydraulic Problem #1
R W
Have a 414 Inter tractor which is losing almost all hydraulic pressure due to
the fact that almost all the oil is being dumped though the Slow/Fast control
port much this is caused by the absence of a piston & spring which are almost unobtainable.
Any opinions on blocking the Slow/Fast port which appears to be a bleed
off arrangment as far as I can make out, this should be easy enough done.
Thank You.
/ 414 Inter Hydraulic Problem #2
How about a needle valve. It can be adjusted from zero flow to off.
A good idea if it could be adapted.
/ 414 Inter Hydraulic Problem #4
Is this a master flow control valve? Rockshaft? SCV? Loader?
Controls 3PH only.
/ 414 Inter Hydraulic Problem #6
Not finding any good info on 414 hydraulics. What became of the original piston and spring? Can you send pictures of the manifold/casting of your flow control?
The original spring & piston were missing when the tractor was purchased, have obtained a S/H spring & piston from a wrecker will fit them tomorrow.
Sorry am unable to post pictures.
/ 414 Inter Hydraulic Problem #8
Woo hoo. Spare parts. Good luck. Let us know how it goes.
Its back together & is working OK.
Thanks for the replies.
2022 EZ-GO ELITE...
2025 IRANCH Tire Changing Machine (A64194)
2025 IRANCH Tire...
2022 EZ-GO ELITE...
2018 International WorkStar 7300 4x4 2,000 Gallon Water Truck (A64556)
2018 International...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
2022 EZ-GO ELITE...
