414 Inter Hydraulic Problem
/ 414 Inter Hydraulic Problem #1
R W
Have a 414 Inter tractor which is losing almost all hydraulic pressure due to
the fact that almost all the oil is being dumped though the Slow/Fast control
port much this is caused by the absence of a piston & spring which are almost unobtainable.
Any opinions on blocking the Slow/Fast port which appears to be a bleed
off arrangment as far as I can make out, this should be easy enough done.
Thank You.
/ 414 Inter Hydraulic Problem #2
How about a needle valve. It can be adjusted from zero flow to off.
A good idea if it could be adapted.
/ 414 Inter Hydraulic Problem #4
Is this a master flow control valve? Rockshaft? SCV? Loader?
Controls 3PH only.
/ 414 Inter Hydraulic Problem #6
Not finding any good info on 414 hydraulics. What became of the original piston and spring? Can you send pictures of the manifold/casting of your flow control?
The original spring & piston were missing when the tractor was purchased, have obtained a S/H spring & piston from a wrecker will fit them tomorrow.
Sorry am unable to post pictures.
/ 414 Inter Hydraulic Problem #8
Woo hoo. Spare parts. Good luck. Let us know how it goes.
Its back together & is working OK.
Thanks for the replies.
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
2014 KOMATSU PC170LC-10 EXCAVATOR (A65053)
2014 KOMATSU...
1990 FRUEHAUF 53' DRY VAN TRAILER (A65054)
1990 FRUEHAUF 53'...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2016 Jeep Grand Cherokee 4X4 SUV (A64557)
2016 Jeep Grand...
LOT OF TRANSPLANTER PARTS (A64278)
LOT OF...
