414 Inter Hydraulic Problem
/ 414 Inter Hydraulic Problem #1
R W
Have a 414 Inter tractor which is losing almost all hydraulic pressure due to
the fact that almost all the oil is being dumped though the Slow/Fast control
port much this is caused by the absence of a piston & spring which are almost unobtainable.
Any opinions on blocking the Slow/Fast port which appears to be a bleed
off arrangment as far as I can make out, this should be easy enough done.
Thank You.
/ 414 Inter Hydraulic Problem #2
How about a needle valve. It can be adjusted from zero flow to off.
A good idea if it could be adapted.
/ 414 Inter Hydraulic Problem #4
Is this a master flow control valve? Rockshaft? SCV? Loader?
Controls 3PH only.
/ 414 Inter Hydraulic Problem #6
Not finding any good info on 414 hydraulics. What became of the original piston and spring? Can you send pictures of the manifold/casting of your flow control?
The original spring & piston were missing when the tractor was purchased, have obtained a S/H spring & piston from a wrecker will fit them tomorrow.
Sorry am unable to post pictures.
/ 414 Inter Hydraulic Problem #8
Woo hoo. Spare parts. Good luck. Let us know how it goes.
Its back together & is working OK.
Thanks for the replies.
PULL TYPE YARD SPRAYER (A64278)
PULL TYPE YARD...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
Dickson Ind. 4080 SX Turbo Blast Asphalt Surface Prep Machine (A64194)
Dickson Ind. 4080...
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
