4110 ROPS height?
/ 4110 ROPS height? #1
homeinOR
Southern Oregon
JD 4110
About to get a new 4110 with normal size R4's and was wondering what the height to the point where ROPS fold was? Would like to put it in the garage and knowing the dimensions(can't find these particulars on JD website) would help. Otherwise will have to get busy on pole barn or the likes! Thanks for help!
/ 4110 ROPS height? #2
before you build a barn measure to bottom of header on garage door, if its tall enough romove old garage door and install double doors that open to the side like saloon doors, like on a barn. i did that and my tractor fits, clears by about 1/2 inch, and its a 00 series mahindra so its a full size ag tractor. by the way this is without folding down the rops.
/ 4110 ROPS height? #3
That measurement was one thing that swung me to buy a 4010 instead of a 2210 or B7510. The 4010 was 77 or 78" with turf tires. The 2210 was 1" higher. B7510 had folding ROPS much higher.
I've a regular garage door in the main deck of the carriage house. It fits there AFTER I adjusted the fitting on the door opener to the upper 2 bolt holes. Even then, I had to move the handle up because it would bump it but push by it. Down below, which is where I keep it now, I have those double doors that swing on hinges inside. It clears there by a couple inches.
Ralph
/ 4110 ROPS height? #4
on my 4115, i have to fold the rops down, then there is plenty of room to put the tractor in the barn. we have 6 ft doors. i would say the fold point is at about the 4ft mark. i never really measured, though. if you can walk into the barn, the tractor will fit with the rops folded. i think it is close to 7ft with the rops up.
/ 4110 ROPS height? #5
Interesting thing.....
I just (yesterday) swapped out a 2210 for a 4110. The 2210 was driven out of the garage just fine, but on the way in the 4110 hit (just barely) the underside of the completely raised garage door. 2210 had R4s, the 4110 came delivered (but not ordered) with turfs.
/ 4110 ROPS height? #6
Just went out and measured my 4110 (2003). 84.5" when in use-- 66" when folded.
/ 4110 ROPS height? #7
With the aforementioned turfs, height to the fold is 65.0. When extended, 83 5/8s. My door clearance (to the remaining un-dented panels) is 83 1/2.
/ 4110 ROPS height? #8
I forgot to say i'm running loaded R4's. That must be the difference.
/ 4110 ROPS height?
Thanks for the measurements guys. Now where to put all those implements!!!!
/ 4110 ROPS height? #10
Mine go into the basement of the carriage house, the section with those double doors. I put my LX4 down on castors, which make it MUCH easier to put on and to take off and to roll away to the side.
Got my soil ripper stuff, drawbar, 2 shredders, freezer and growing rack all in there, with cabanas in the 2 inlet corners to each side of the double doors. Some leftover cabinets are in there, too.
Ralph
/ 4110 ROPS height? #11
What about the 4110 ROPS height for a fixed (non-folding) ROPS with turf tires? I'm probably going to buy a 4110 this week, but this is something I really need to find out. I know it will be tight getting it under my garage door opening. Dealer couldn't tell me the height and didn't have one in stock.
Thanks,
Ira
/ 4110 ROPS height? #12
I believe (not absolutely sure) that RaphVA's numbers are for the fixed ROPS-----no doubt that the folding 4110 ROPS in the up position is higher than a 2210's fixed.
/ 4110 ROPS height? #13
I think RalphVA was talking about a 4010 and I'm looking at a 4110...
From RalphVA's post...
"That measurement was one thing that swung me to buy a 4010 instead of a 2210..."
Is a 4010 and 4110 ROPS height the same? It would be great if they are because that would leave me a couple of inches clearance.
Thanks,
Ira
/ 4110 ROPS height? #14
This page contains ROPS heights and other stats:
http://www.rnjohnsoninc.com/jd/jd_equ1.html
Of course, they don't specificify what style of ROPS is being measured. Guess we know for sure the folding model is taller----or at least it is now. Good luck.
/ 4110 ROPS height? #15
My 4110, with R4 tires at max pressure, folding ROPS, is exactly 84 3/4 inches from the floor.
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
CF Grapple (A64127)
CF Grapple (A64127)
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2013 Chevrolet Silverado Service Truck (A62613)
2013 Chevrolet...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
excavator trenching bucket- one bucket per lot (A63689)
excavator...
