4110 battery
/ 4110 battery #11
DO IT!!!!
I also have a 2000 4300 and did have some leakage though not the destruction that others have had. Luckily Stuart has not had a problem. I actually just finished pulling out the front metal plates that support the battery. I then wire wheeled them, chemically removed the rust. and painted with good paint...hope it works.
I also have a yellow top Optima. I had to fabricate a hold down angle but that was no trouble...happy to send a pic if ya want. Make the change now and prevent the problem.
This is also not just a JD problem, it happens to all.
Peter
/ 4110 battery #12
</font><font color="blue" class="small">( I have a 4300 , 2000 model and haven't experienced any battery problems though I keep looking every month. It seems to be a hit or miss. My guess is that most of the batteries are fine.
)</font>
<font color="green">Stuart, is your tractor used on level ground or pretty much level ground? I have been wondering if the tractor battery acid problems might be more prevalent for those who use their tractors on hills and in hollows, like me.
Mike </font>
/ 4110 battery #13
Or bumpy ground mowing at high heat...
I never thought I had a problem, either, then I puuled tha battery out, and all the damage was hidden by the battery!
/ 4110 battery #14
The Optima D51 is available at Remy for under $100. The dealer will credit $50 for the stock battery. Based on my experience, and many others posted here, $50 is cheap insurance, and money well spent.
The hold-down hardware on the 4110 fits the Optima perfectly. No modification or fabrication is necessary.
/ 4110 battery #15
I do use mine on hilly and very rough areas...maybe thats why I had the problem a bit. And glad to hear the 4110 needs no mod to fit the optima. Th 4300 has small plates that held the lower edge of the old battery. The optima doesn't have this edge to grab...needed a top strap.
I just feel bettter with the optima....now if I can just fix those rollback cylinders...hmmm
Peter
/ 4110 battery #16
On the 4110, be cautious torque-ing the "plastic" hold-down bar. Mine snapped with what seemed like a pretty light tightening. /forums/images/graemlins/mad.gif
/ 4110 battery
Thanks for the input guys. Great news that the Optima D51 will fit the 4110 without mods! I ordered one from Remy & it should arrive before the tractor does next Thursday, so I can get it to the dealer for swap out & installation. So far, my dealer & salesman have been GREAT, and I got 3 hats when I finalized the deal - must be my baby blues. /forums/images/graemlins/grin.gif If I can just stay busy & distracted until Thursday...
BTW, my salesman said there's a big JD meeting in FL the week of 10/25 re the new models. Hmmmm, just in time for the Christmas buying spree???
/ 4110 battery #18
</font><font color="blue" class="small">( Hmmmm, just in time for the Christmas buying spree??? )</font>
Sounds like I need you to talk to my wife... /forums/images/graemlins/smirk.gif
/ 4110 battery #19
My 4210 has 219 hours on it, and I serviced it at 200 hours. As I always do while servicing, I remove the side panels and tilt the front grille out, and clean the debris out of the engine compartment. To clean the hydro radiator, I loosen the battery hold down and pull it forward, and this time I found white deposits crusted onto the radiator that were pretty much concealed by the battery. I took some pics of the area before cleaning the deposits off and reinstalling the battery.
Next service will be at 240 hours, and I am wondering if the problem will recur, so I priced the Optima batteries at a local auto parts retailer (Murrays) and the red top has a much better warranty than the yellow top model does. Would anyone know why the warranties are so different? /forums/images/graemlins/confused.gif
/ 4110 battery #20
mhalla: yes my tractor is used mostly on level ground. I have a couple of hills but no valleys or hollows to speak of. Do you think that battery leakage is caused by or related to the type of ground the tractor is used on?
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
2020 Ford Ecosport 4WD SUV (A59231)
2020 Ford Ecosport...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
KJ K4525 45'x25' Double Garage Barn Shed (A60463)
KJ K4525 45'x25'...
19008 (A56859)
19008 (A56859)
4ft Mini Skid Quick Attach Rotary Cutter (A61307)
4ft Mini Skid...
