4035 Pic
/ 4035 Pic #22
I use my 15hp, 4x4 Bolens/Iseki tractor to pull entire tree lengths out, but with the top cut off. I usually cut the tree into about 25 foot sections, and then tow that out. The trees are around 24in+ at the base and are all hardwoods. So far, the only thing that has held me back, is the ocassional tree stump, or rock in the way.
This year, I am making a homemade log skid using two tractor draw bars. I am attaching a steel skidding tong to my 3 point draw bar, and then at the other end of the log, I am going to use another draw bar that I have lying around, and I am putting tires on the part that would attach to the lift arms. This end, I will put under the log at the oposite end away from the tractor, and attach it with a ratcheting tie down strap. This should allow me me to skid larger logs out of the woods, without dragging the log in the dirt, and dulling my chain when I cut it. Hopefully it works.
/ 4035 Pic #23
This will take a great deal of friction off the pull Mitch. You'll have to build your "dolly" to withstand at least 500# of weight. The other situation you'll confront is the battering the dolly will take as it gets pulled along. This of course depends on the density and ground obstructions you have.
/ 4035 Pic #24
I love my 4035.
I doubt your 4035 would have little trouble dragging out the tree pictured. This one took me 3 turns. One for the stem and two for the crown. I need a tractor that will do this in one shot but able to go maneuver in dense woods.
/ 4035 Pic #25
The wheels say that they are rated for 300lbs each, so I am not sure how well they will work. The problems is in order to attach them to the draw bar, they have to have a 7/8" axel bore. That is actually very hard to find. I guess I can try it, the wheels are very inexpensive, s0 worst case senario, they break, and I loose out on like $21. Thanks for the input, I really had not thought about the battering it will take. The woods that I am going to be pulling out of have soft to hard packed ground, with minimal to no obstructions, just logging roads, and I will not be going that far. Usually about 1000 feet or so. Anyways, thanks again!
/ 4035 Pic #26
I've been contemplating buying a tractor for the last 3 years. The wife says not until mine breaks or I die can I get a new tractor. The latter will be a replacement for the 72 virgins others will get. I stood next to a 4035 a week ago as Mahindra is the closest dealer to me. Compared to my JD 750, its a monster. I know how well the JD goes through our very dense N.E. woods so I am always concerned about increased load capacity as it relates to skidding trees and maneuverability with a larger machine. I'd love to be able to drag out a 60' tall 20" wide oak in one shot instead of the three trips it takes now ( two for the stem and once for the crown) especially that I am going further out on the acreage to harvest firewood. I used to own a JD 950 along with the 750 and thought it was a wee bit large for our woods. Perhaps at the time, it was just that I was used to the maneuverability of the 750. For some reason the 4025 looked smaller in the pictures but I know its not. It is not as prettied up so as to not mind too much when it starts to get woods dinged.
I really need as small a tractor as possible that can still drag out an entire oak and I do not know if the two factors equate.
Chriss 3055, congrats on a fine tractor! I recently bought its baby brother (2516)
Arrow, I also cut my own wood,once I get the bottom of the tree lifted up off the ground it drags pretty easy. But I only drag it to where I can process it in the woods and haul my split firewood in my trailer.
/ 4035 Pic #27
Here's mine doing some work.
/ 4035 Pic #29
Yea I used it for fill on a beaver **** crossing. Been saving till I needed it.
/ 4035 Pic #30
On this day, I needed your tractor. This would not even fit in the bucket let alone pick it up out of the bucket.
/ 4035 Pic #31
I had a John Deere 240 skidloader prior to my tractor and I was surprised with the hydraulics would lift on the tractor.
/ 4035 Pic
Hydro,
That pic is awesome. It is amazing what can be done with these machines!!!
I have to get my rear tires filled so that I can get the true sense of what this machine can handle. I see that you have a finish mower on the back in the photo. That extra weight has to help so much. I have a local guy that used to be a tractor/implement dealer. He still has a rim guard set up and filled tanks out back. I am going to get my tractor over to him and get the rears filled. Its going to help so much with the grapple work I have lined up.
Again, Love that pic!!! :thumbsup:
/ 4035 Pic #33
Thanks so much!!! I don't have my tires loaded, but usually have an implement on the back. Most of the time it's a rollover box blade. It amazes me all the time!!!
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
16ft. Teak Wood Table (A61574)
16ft. Teak Wood...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
