4035 Pic
/ 4035 Pic #22
I use my 15hp, 4x4 Bolens/Iseki tractor to pull entire tree lengths out, but with the top cut off. I usually cut the tree into about 25 foot sections, and then tow that out. The trees are around 24in+ at the base and are all hardwoods. So far, the only thing that has held me back, is the ocassional tree stump, or rock in the way.
This year, I am making a homemade log skid using two tractor draw bars. I am attaching a steel skidding tong to my 3 point draw bar, and then at the other end of the log, I am going to use another draw bar that I have lying around, and I am putting tires on the part that would attach to the lift arms. This end, I will put under the log at the oposite end away from the tractor, and attach it with a ratcheting tie down strap. This should allow me me to skid larger logs out of the woods, without dragging the log in the dirt, and dulling my chain when I cut it. Hopefully it works.
/ 4035 Pic #23
This will take a great deal of friction off the pull Mitch. You'll have to build your "dolly" to withstand at least 500# of weight. The other situation you'll confront is the battering the dolly will take as it gets pulled along. This of course depends on the density and ground obstructions you have.
/ 4035 Pic #24
I love my 4035.
I doubt your 4035 would have little trouble dragging out the tree pictured. This one took me 3 turns. One for the stem and two for the crown. I need a tractor that will do this in one shot but able to go maneuver in dense woods.
/ 4035 Pic #25
The wheels say that they are rated for 300lbs each, so I am not sure how well they will work. The problems is in order to attach them to the draw bar, they have to have a 7/8" axel bore. That is actually very hard to find. I guess I can try it, the wheels are very inexpensive, s0 worst case senario, they break, and I loose out on like $21. Thanks for the input, I really had not thought about the battering it will take. The woods that I am going to be pulling out of have soft to hard packed ground, with minimal to no obstructions, just logging roads, and I will not be going that far. Usually about 1000 feet or so. Anyways, thanks again!
/ 4035 Pic #26
I've been contemplating buying a tractor for the last 3 years. The wife says not until mine breaks or I die can I get a new tractor. The latter will be a replacement for the 72 virgins others will get. I stood next to a 4035 a week ago as Mahindra is the closest dealer to me. Compared to my JD 750, its a monster. I know how well the JD goes through our very dense N.E. woods so I am always concerned about increased load capacity as it relates to skidding trees and maneuverability with a larger machine. I'd love to be able to drag out a 60' tall 20" wide oak in one shot instead of the three trips it takes now ( two for the stem and once for the crown) especially that I am going further out on the acreage to harvest firewood. I used to own a JD 950 along with the 750 and thought it was a wee bit large for our woods. Perhaps at the time, it was just that I was used to the maneuverability of the 750. For some reason the 4025 looked smaller in the pictures but I know its not. It is not as prettied up so as to not mind too much when it starts to get woods dinged.
I really need as small a tractor as possible that can still drag out an entire oak and I do not know if the two factors equate.
Chriss 3055, congrats on a fine tractor! I recently bought its baby brother (2516)
Arrow, I also cut my own wood,once I get the bottom of the tree lifted up off the ground it drags pretty easy. But I only drag it to where I can process it in the woods and haul my split firewood in my trailer.
/ 4035 Pic #27
Here's mine doing some work.
/ 4035 Pic #29
Yea I used it for fill on a beaver **** crossing. Been saving till I needed it.
/ 4035 Pic #30
On this day, I needed your tractor. This would not even fit in the bucket let alone pick it up out of the bucket.
/ 4035 Pic #31
I had a John Deere 240 skidloader prior to my tractor and I was surprised with the hydraulics would lift on the tractor.
/ 4035 Pic
Hydro,
That pic is awesome. It is amazing what can be done with these machines!!!
I have to get my rear tires filled so that I can get the true sense of what this machine can handle. I see that you have a finish mower on the back in the photo. That extra weight has to help so much. I have a local guy that used to be a tractor/implement dealer. He still has a rim guard set up and filled tanks out back. I am going to get my tractor over to him and get the rears filled. Its going to help so much with the grapple work I have lined up.
Again, Love that pic!!! :thumbsup:
/ 4035 Pic #33
Thanks so much!!! I don't have my tires loaded, but usually have an implement on the back. Most of the time it's a rollover box blade. It amazes me all the time!!!
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
2014 CATERPILLAR 140M2 AWD MOTORGRADER (A62129)
2014 CATERPILLAR...
2014 Subaru XV Crosstrek SUV (A61569)
2014 Subaru XV...
UNUSED KJ 33'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 33'X25'...
2024 John Deere 6R 155 MFWD Tractor (A63109)
2024 John Deere 6R...
