4035 Tire Pressure?
/ 4035 Tire Pressure? #1
lantxinNETX
Bronze Member
NE Texas
Kubota BX23S
Anyone know what the correct tire pressure is supposed to be for a Mahindra 4035?
I will be honest that I haven't been checking the pressure too often . . . and I can't find it listed either on the tractor or in the Owner's Manual.
I can see the 'do not exceed' pressures on the tires . . . I am thinking the fronts should be around 35 psi and the rears (unfilled) about 20.
Martin
/ 4035 Tire Pressure? #2
I inflate my fronts to max sidewall pressure because I use the loader frequently. The rears are around 15 psi.
Many recommend the rears be adjusted by tire footprint (full tread contact) but my R4's don't seem to ever change the footprint regardless of the pressure.
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
2019 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2019 CATERPILLAR...
2017 Ford F-150 Crew Cab Pickup Truck (A68183)
2017 Ford F-150...
213063 (A64276)
213063 (A64276)
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
2011 SPM SAFETY IRON 100 BBL 10 PUMP MANIFOLD TRAILER (A67714)
2011 SPM SAFETY...
