4035 Lights
/ 4035 Lights #1
tjus77
Montgomery, TX
Mahindra 4035
Is there such a switch that could be wired to cut the ROPS white lights off when I turn the rear facing light on? Currently have the bulbs taken out because I just can't see anything looking backwards with them on, which is a pain when I'm moving a hay bale in the dark.
Thanks
/ 4035 Lights #4
Another option is to put a new set of brighter LED lights pointing backwards [ forwards too if you want ] onto your ROPS and use them 24/7 or switched. They are up high enough that they should not bother you. I mounted 27 watt LEDs on my 5035 years ago, and they have much higher wattage/brighter ones avail now fairly reasonable on EBAY or AMAZON. I have mine wired onto the Worklight circuit but leave them on all the time. They draw very little current. They help when entering/exiting the barn.
