400 rear PTO not engaging
/ 400 rear PTO not engaging #1
LVFross
Iowa
TYM 400
I was using it the other day for the first time in a while. Today the rear PTO will not turn. Dash light is on. Any ideas?
/ 400 rear PTO not engaging #2
Just to double check make sure the manual-auto switch is on and the 540 gear lever is locked in position. With these checked the next thing is to go under the tractor and make sure the wires are hooked up on the solenoid that engauges the pto clutch. Sometime this can get caught on brush and pull a wire off. These are the first things to check that I know of.
/ 400 rear PTO not engaging #3
This is from a old post
New to this forum but not tractors!
Did a seach on here for TYM T400(2004) tractor that I got, The pto was never used so it wasn't turning. Found out about the button under the right floorboard from a old post, Pushed it and now have a working pto!
THANKS FOR THE GREAT FORUM HERE!!!!!
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A68183)
1995 Khronert 307...
CAT D5N Winch (A68134)
PORTA POTTY (A67714)
2014 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A65056)
2014 CATERPILLAR...
Unused 2022 Hustler Lift Max LE110 SS Bale Forks and Frame Tractor Loader Attachment (A66734)
Unused 2022...
2025 48in Land Leveler Skid Steer Attachment (A66734)
2025 48in Land...
