Oil & Fuel 400 hr check- necessary
/ 400 hr check- necessary
hads good luck using tractor supply universal transmission fluid it so i guess i'll stay with that- we use it in about everything around here-big big diff in price from kubota super udt
okay-you guys win-------I'll use udt-dealer said super udt not necessary in the South and he doesn't even carry it- they use it up North where it is colder as it's thinner- so i learned something today- he did say 90 % of the kubota problems that they see are because people don't change the fuel filter on a regular basis-[$13 ]-he said it should be changed each time the oil is changed or every 100 hours-so we'll do this also---------Have a great days all you guys and gals.
/ 400 hr check- necessary #22
On fuel filters, unless there is water in it, will take one next to engine and replace it with new one and put the old one in place of the one before fuel pump.
David Kb7uns
/ 400 hr check- necessary #23
Fifthteen thousand for new ctutch packs and of course while your in there seals. SO yeah when the oil gets old and saturated with water the cheaper tractor hydraulic oils turn acidic from what the mechanic said and it eats at the adhesive in the clutch linnings. So change the oil if it is milky and use the better oils.
David Kb7uns
That must have been a big tractor then. 15K is almost 3/4 the total cost of my tractor w/loader. Or was that because it is a green one?
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2020 John Deere R4044 Sprayer (A63111)
2020 John Deere...
2021 UTILITY VS2DX 53x102 T/A DRY VAN TRAILER (A59912)
2021 UTILITY VS2DX...
(2) UNUSED 14X17.5 TIRES W/ 8 LUG RIMS (A64280)
(2) UNUSED 14X17.5...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
