4 in 1 bucket tip
/ 4 in 1 bucket tip
I used the kit supplyed by long, it works ok. If you go back and look at some of the posts by Mark he explains some of the other options. when I dump the bucket at higher rpm say above 1800 rpm it some times chaters/jumps and it does dump slower, but not enough for me to look for a biger valve bank any time soon. Rember this is on a L4610 witch has a higher flow, gpm than most 9.6 gpm. Long told me that the pump would handle 11-12 gpm. I would see if they have a bigger one if you have a high flow rate.
Rich
/ 4 in 1 bucket tip
forgot - the button on the joy stick is the only way to go. I would'nt even think of having a valve on the fender. Here's your 20' pole /w3tcompact/icons/smile.gif
Rich
/ 4 in 1 bucket tip #23
Brings back good memories!!!!:)
/ 4 in 1 bucket tip #25
Man that idea is just to simple! Once I read your post I just did a head slapper---why didn't I think of that! Guess that gives me another reason to drool over the 4in1 bucket that I don't have./w3tcompact/icons/frown.gif
Gordon
/ 4 in 1 bucket tip
Thats a spil plate that long charged a extra $35.00 for, but would'nt sell it with out. Im glad, on a L4610 if you roll it back it all the way and pick it up 8' you will eat dirt, even with it you must keep rolling it forward.
Rich
/ 4 in 1 bucket tip #27
Richh, thanks for the reply on the solenoid and thumb switch. On Marks 4 in 1 bucket post, he mentions that on a 'regenerative' circuit dividing the bucket hyd circuit with the solenoid diverter valve weakens the clamping action of the clamshell rams. This is because the solenoid ends up pressurizing both sides of the clamshell in the same manner used when applying pressure to the bucket tilt rams. Did I read that right, or am I off base here. Another question. I take it that the thumb switch has two buttons, one for closing and one for opening the clamshell?? Is there a pic on the thumb switch to look at?
Talked to Longs and they did not mention the spill plate shown in your pic. It looks like a good idea.
And lastly, what do you think the difference in weight was between you OEM bucket and the the 4 in 1 job?
My JD 970 has and 8gpm hyd pump so I'm hoping that will be low enough to not cause the chatter problem.
thanks again,
george
/ 4 in 1 bucket tip #28
George - The "weakening" of the clamping pressure doesn't have anything to do with the solenoid valve, it's because of the way a regenerative circuit works. The solenoid valve just diverts the flow from both sides of the loader's dump circuit valve to the 4-in-1 bucket's cylinders instead.
That brings us to your question about the thumbswitch. There's only one thumbswitch. When you push the button, all flow from the dump/roll back circuit of the loader valve is diverted from the dump/roll back cylinders to the 4-in-1 bucket cylinders. So, the way it should work is this: When you push the button and move the joystick to the roll back position, the 4-in-1 bucket closes; if you move the joystick to the dump position with the button depressed, the bucket opens. However, with a regenerative circuit, if you try to hook it up so it works this way, the bucket will close either way you move the joystick. To make it work, you have to reverse the hydraulic connections to the bucket so it opens when you move to the roll back position and closes when you move to the dump position. This makes it pretty awkward to use because you generally want to close and roll back at the same time or open and dump at the same time. Without a regenerative circuit, you can alternately roll back and close the bucket by simply moving the joystick to the roll back position and pressing and releasing the thumbswitch. Unfortunately, you have to change the valve spool in the loader to change the regenerative circuit to a non-regenerative one.
If I remember correctly, the difference in weight between the standard 5 foot bucket and the 4-in-1 5 foot bucket is a little over 300 pounds.
MarkC
/ 4 in 1 bucket tip #29
The best way to go overall is to replace the spool valve that comes with the loader with a Husco that Kubota also sells? You still can have some valve chatter in full dump mode? But you have full strengh in clamping and opening of the clam shell. What about regular dumping of the bucket--still the same or slower. Also in rollback you have more power or the same amount? Guess that questions me out for now---inquiring minds want to know! The four in one has been on my want list and the better informed I am the better off I will be. When I do get enough pocket jingle to have a have one sitting in front of my tractor.
Also Mark and others you have had your bucket for awhile now how has it held up overall. Any noticable bending or flexing? Would you do anything different now that you look back at it? Bottom line is it worth the investment--I believe it is looking at it from a production standpoint and what can be preformed with it but like I said I don't have one so I'm on the outside looking in.
Can the bucket be mounted with a quick-attach setup? To enable you to run other bobcat style implements?
I know I said enough questions for now up top but I fibbed. Now how wide of a bucket did you guys go with to compensate for the extra weight and I guess a very important question does it cover your tire tracks?
Thanks in advance for any help
Still drooling for a 4 in 1
Gordon
/ 4 in 1 bucket tip #30
Gordon - First, some definitions: (You probably already know all this, but I just wanted to make sure we're on the same page because it's a little complicated.) The loader valve is a two-spool valve manufacturered by, as you said, Husco. The valve block is the casting that the two shiny chrome rods, the spools, slide in. The spools are connected to the joystick in such a way that when you move it forward and backward (or up and down, or in a plane parallel to the longtitudinal axis of the tractor, however you prefer to say it /w3tcompact/icons/wink.gif) the leftmost spool (as viewed by the operator when sitting on the tractor) moves out and in, causing the lift cylinders to lower or raise, respectively, the bucket. When the joystick is moved right to left (or side to side, or in a plane perpendicular to the longtitudinal axis of the tractor, however you prefer to say it), it causes the rightmost spool to move in and out, causing the bucket to dump or roll back, respectively.
The rightmost spool (the dump circuit spool) has a normal rollback circuit, and a regenerative dump circuit. The advantage of a regenerative circuit is that the volume of flow is as much greater than the flow of a non-regenerative circuit as the volume of the sectional diameter of the rod in the cylinder. (Meaning that you can't predict exactly how much faster it will be in general because it depends on the volume of fluid displaced by the rod, which can be different sizes.) The disadvantage is that the force generated is reduced by the same amount. Generally, this isn't a problem in the dump side of a dump/roll back circuit, because dumping is gravity-assisted anyway. There's pretty much always enough force available to lift the front of the tractor (as when backdragging under pressure), so any more force isn't usable anyway.
The problem comes in when you're trying to use the dump/rollback circuit to actuate a 4-in-1 bucket. The preferred way (from a usability standpoint), as I mentioned in the earlier posts, is to clamp with the roll back circuit and open with the dump circuit. When you try to open with a regenerative dump circuit, however, it won't work, because you can't retract a cylinder using regeneration - by definition it can only extend the cylinder because that's the only way there's a pressure differential. And extending the cylinders on a 4-in-1 bucket causes the bucket to close. Therefore, the result is that the bucket closes when you use the roll back mode (with the thumbswitch actuating the solenoid valves, causing the fluid flow in the dump/roll back circuits to be diverted to the 4-in-1 cylinders) the bucket closes, and when you use the dump mode to try to retract the cylinders to open the bucket, they extend and the bucket still closes. The result: You can't open the bucket, period.
There are two (technically three) solutions: (I'm repeating what I said in the earlier posts here, but it's relevant) reverse the hoses so the the roll back circuit opens the bucket and the regenerative dump circuit can close it (since that's the only thing it will do anyway). Disadvantages to this approach: The 4-in-1 bucket is a royal pain to use this way (from a usability standpoint) for reasons I mentioned in the earlier posts, and just as important, the clamping force available is reduced as described in the discussion on regenerative circuits above - not a problem in dump circuits, but a big problem in 4-in-1 clamping circuits.
The second solution: Get rid of the regenerative dump circuit. The only way to do this is to change the rightmost spool in the valve body.
The third (technically the same as the second, except in usability) solution: Have both a regenerative and a non-regenerative dump circuit. The only way to do this, as with solution two, is to change the rightmost spool in the valve body.
Fortunately, Husco makes a spool that has both a non-regenerative and a regenerative dump circuit. It works much like the float circuit on the lift spool: If you push the joystick to the right about halfway, you get a non-regenerative dump. If you push it past the detent and hold it (it won't stay there like it does with the float mode, for obvious reasons), you have a regenerative dump. This is, obviously, the way to go.
Next problem: How do you get your hands on this spool? I'm afraid I can't help you with this, except to say that if you have a highly motivated dealer, he can get his hands on one through Kubota. Husco doesn't sell in quantities less than a 1000 or so, so that's out. The problem in getting it from the dealer is that he most likely won't have a clue what you're talking about and you're not likely to be able to explain it to him, either (because he won't understand, not because you can't explain it). My suggestion is that you tell him you need a replacement dump/roll back spool for the Kubota L-series remote-mount loader valve. This valve comes with the combination non-regenerative/regenerative dump circuit described above. Reason: it's made to work with stuff other than just loaders, and they know you can't retract a cylinder with a regenerative circuit.
So, to answer your questions: Yes, the best approach is to replace the dump/roll back valve spool. It's a 10-minute job, as long as you have the right size allen wrenches (the ball-type ones make the job a lot easier). And keep everything very clean. (The rest of the answers assume that you take this approach.)
You will still have some chatter when using regenerative mode to dump the bucket, unless you forego Long's electrically actuated valves and use a higher capacity valve block. I can give you details on this, if you need them (but I think they're in the 'L4310 Enhancements' thread).
Dumping will be just a little slower in regenerative mode unless you forego the Long valves to eliminate the chattering as mentioned above.
In roll back mode you have the same power - no change.
As for durability: Long makes two different versions of the 4-in-1 bucket for tractors. (They may make a huge one for very large ag-class tractors, but I'm not including that one.) The Hydro-Jaw I and II. I think (but I'm not sure) that the Hydro-Jaw I is the heavier-duty one. At any rate, there's a significant difference in the duty class and weight between them. The heavy duty one is not suitable for anything smaller than the LA-681 (1500 lbs bucket capacity) loader, in my opinion, because it's just too heavy. I've seen the lighter duty one (belonging to a friend of mine) get bent by extremely heavy usage, but I've not bent the heavy duty one at all, except for some bulges in the back of the bucket where I've rolled very large rocks into it. This bucket is much heavier duty than Kubota's heaviest bucket. My guess is that if I haven't bent it, it's just about impossible to bend it. Remember, too, I've got the 2 1/2" lift cylinders.
Also, I do think it's an extremely good investment - I wouldn't want a tractor without one anymore, that's for sure.
I wouldn't do anything different with the 4-in-1 than the way mine is set up right now, except that I'm planning to weld some teeth to the side of the jaw to assist in picking up logs. And I'm thinking about installing a quick-attach mount, which answers that question, though I don't have any ideas yet on the best way to do it.
I went with a 5 foot bucket. The 6 foot one is just too heavy, in my opinion. That means it doesn't cover the tire tractors, at least not my tire tracks. /w3tcompact/icons/wink.gif
Sorry for the verbosity - hope it helped.
MarkC
/ 4 in 1 bucket tip #31
Mark you got me---verbosity that really is a word!!! Now were cookin. Great post and thanks I gathered up most all of my questions and when I couldn't hold them back anymore, I let loose all at once. Great info you posted and I bet it's easy to write now but alot of it was hard learned through trial and error.
Guess that Long doesn't make a 5-1/2' bucket. From the sounds of it with the rocks you have moved or should I say small boulders and just some dings in the bucket its darn tough. How has the tooth bar held up over time did you get that from long as well? Replaceable pinned teeth or welded on teeth?
Thanks for that good old Mark post!!! I'm ready for anything now I've got the dictionary by my side./w3tcompact/icons/smile.gif
I got a private e-mail from someone who shall remain nameless and he said that the tires Michelins were more than worth the hassle of mounting them. He said that you just can't believe the traction and footprint in the woods. Great floatation as well. You should have told me about those tires and how good they really are Mark. /w3tcompact/icons/smile.gif
The p.s. was everything you heard about the tires is true.
Ok guys just make me drool/w3tcompact/icons/smile.gif
Gordon
/ 4 in 1 bucket tip #32
Gordon - You're always welcome, of course. You're right, it took a long time to figure all that stuff about the regenerative circuits out. I was the first one to report the problem to Long and they were very puzzled as to what was going on. A friend of mine and I eventually figured it out and told them our theory - they agreed it had to be that, but told me I'd just have to live with the reversed hoses, that it was the only way I could get it to work. I wouldn't settle for that, of course, and the rest is history.
The tooth bar also came from Long. It has peened-on teeth, but they're in no danger of needing to be replaced anytime soon. It's holding up extremely well.
As for the tires, I did tell you about them: The original posts in the "L4310 Enhancements" thread told everything. Where do you thing the person who sent you the private e-mail heard about them from? /w3tcompact/icons/smile.gif As for the identity of the person who sent you the private e-mail, it's no trouble figuring out who he is, if he's a poster on this forum - only one other person has bought those Michelins and installed them. In fact, he put me on the trail of a place to buy the front tires at a much lower price than I'd found! I'm glad to hear he's happy with his. I sure am with mine.
MarkC
/ 4 in 1 bucket tip #33
What got me thinking about the tires is, today I had the skidding winch on the back of the tractor and we just got a good bit of rain overnight and also some today. But I still tried to do alittle skiding without the tractor chains. Did some spinning on the third trip out once the trail got alittle soft in a couple of spots. I had her loaded pretty heavy though. A new part of the trail that I built last week. Hasn't packed out firm yet. Back to my point. I was wondering how well or if I would have had any wheel spin at all with the mac daddy tires. Time will tell about that one. It won't be this year but in the future I'll have a set of those tires.
But it's a toss up on which way to go first. The 4-in-1 or the tires first. My checkbook wont allow both. Unless I find a few nice veneer trees that are hidden in those woods and a good market for them. Or maybe if I'm real lucky some or even a birdseye maple--worth about $6000-12,000 for one log!!! But they are supposed to be extinct in the state of DE. But one never knows./w3tcompact/icons/smile.gif
Gordon
/ 4 in 1 bucket tip #34
Gordon - I don't have to think long about which I'd rather give up. I'd much rather give up the tires than the bucket. There's things you can do to compensate for poorer tires, like chains, or just working more slowly, but it's hard to replace that 4-in-1 bucket!
MarkC
/ 4 in 1 bucket tip #35
Good point Mark. Some things you can work around but other things just help with production and making the job go easier.
I think I've figured out the perfect test!!! For a period of three months we could trade buckets and tires just to see which one I would miss more when you take them back. How does that sound!!!??? Man if I could talk you into that one I would quit my day job and go into sales./w3tcompact/icons/smile.gif
Gordon
/ 4 in 1 bucket tip #36
Gordon - Um, don't bother quitting your day job... /w3tcompact/icons/smile.gif
MarkC
/ 4 in 1 bucket tip #37
I'll answer the "holding" up under use question.
I've only got 68 or so hours on the tractor but much of that is using the 4n1 FEL. I have moved tons and I do mean tons of logs and stumps with this thing. I still laugh when I pick up some of the large timbers, 12-15 feet long 20+ inches in diameter. I can barely roll the logs so picking them up with the FEL still boggles my mind.
The key to prevent bending of the bucket is to pick the logs up 90 degrees to the timber. You want both sides of the bucket to grab the timber at a minimum. If the top and bottom of the bucket grab on that is even better.
If you must grab something that violates the above approach then try to center it in the middle of the bucket.
The damage I have done to the bucket has been bending the sides and teeth when grabing a log and pulling at an angle. Sometime you just gotta do what you gotta do. Pulling at an angle will force the end of the log into one side of the bucket. The log weight and drag will cause a part of the bucket to move out of alignment. My 4n1 has two teeth on the inside of the bucket that will lock into logs that are being grabbed. I have bent them as well.
The fix is real simple. A hammer or sledge works in getting things back into alignment. :cool: Course it is better to prevent the problem in the first place.
I don't have any teeth, except for the two mention above, on the bucket. I push the bucket into the log with the bottom edge parallel to the log. I then grab the log with the bucket which moves the timber a bit. I then roll the bucket back which moves it into the lower part of the bucket edge. I clamp down to make sure that everything is secure and off I go.
Hope this helps...
Dan McCarty
/ 4 in 1 bucket tip #38
I just used my Long's 4n1 to move ~100tons of 16" rock. I drove into the pile and scooped it up. My bucket hardly has a scratch on the paint. My neighbor helped for a while and bent the cutting edge and dented the back of his standard Kubota bucket. I'd say it's quite a bit tougher than anything Kubota makes.
Dave
P.S. I did the hydraulics by replacing the joystick with the remote mount joystick. It not only has a non-regenerative dump but is also easier to reach. A more expensive option, however.
/ 4 in 1 bucket tip #39
Gordon - I guess I could've done a little more thorough job addressing the durability question, but by the time I got to that one, I was tired. /w3tcompact/icons/smile.gif
My Long 4-in-1 bucket is on its 3rd tractor and has about 800 hours of use on it. You can see from the pictures in the "L4310 Enhancements" thread what kind of shape it's in. As I mentioned before, it gets lots of abuse and never complains. I routinely lift stuff 75% heavier than the L4310 is supposed to be able to, for example. I've used the clamp as an "instant chainsaw" many, many times, too. For the past couple months, the right side cylinder has been leaking a little - and that's the first problem I've ever had with it.
MarkC
/ 4 in 1 bucket tip #40
Yea I did blast out a bunch of questions all at once. I have figured out two things. First a long bucket would be without a doubt a great long term investment. Second I won't be going into sales any time soon.
A couple of the others with the long bucket also posted on there toughness. All the same results a very well built product. Seals go over time in the hydraulic cylinders, sounds like it's time for a rebuild kit. Or take it to the hydraulic shop and have them do it.
Ok now you also went with a heavier duty solinoid valve to get rid of the chattering problem. Just a stronger solinoid or the entire valve assembly? I went through the entire 4310 post last night and it must be in the old posts I will go there tonight and see if I can find the posting on it.
As for the spool valve you just changed the outermost spool? I guess in a worst case situation I would have to buy the entire valve body for the remote mounted valve. That is what I've got on my loader now because of my cab. It's a remote mounted that is cable operated. The valve has seen it's better days but still works for me. I guess if you had a cab tractor with the four in one bucket the problem would be solved without having to do anything but go to a heavier solinoid valve to operate the jaw on the bucket.
Gordon
Bobcat T66 Compact Track Loader (A64047)
Bobcat T66 Compact...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
JMR Tree Boom Skid Steer Attachment (A61572)
JMR Tree Boom Skid...
Auger Drill Bit (A61572)
Auger Drill Bit...
Great Dane Van Trailer 1989 (A63118)
Great Dane Van...
2021 Soil Warrior 4500 (A63116)
2021 Soil Warrior...
