3PT. weight limits
/ 3PT. weight limits #1
randy1687
I have a little kubota b7510 at my farm. I think the front end loader has around a 400 lb. limit, it is a 272 I think, but what about the 3 point lift?,. My box blade, cultivator, brush hog weight around 400-500lb. each, but what is the limit?. And is there a safety valve that would prevent you from blowing the seals?. New to tractors and could use some advise.
/ 3PT. weight limits #2
FWIW, the Kubota specs list 3 pt hitch capacity for the hydro version of the B7510 at 615 pounds at lift point and 480 pounds at 24 inches behind lift point. I run a woods GB60 box blade that weighs 495 pounds on my B7610 (which has the same lift capacity as B7510) and I have not had any issues to date.
/ 3PT. weight limits #3
Pretty much every hydraulic control valve has a relief built in to prevent damage to the pump and seals, etc. This includes the 3ph control.
/ 3PT. weight limits #4
I wouldn't count on -every- hyd valve having a relief.. but depending on how it taps the tractor system, the tractor system may still have a relief in line.
Dang.. those are some low lift numbers.. how much does that tractor weigh?
soundguy
/ 3PT. weight limits #5
That can't be right. My little tc 21d is some 1200 lbs. rear lift.
Brad
/ 3PT. weight limits #6
Find your manual or order one. The exact numbers for your rig are in there. It also some other useful stuff.
/ 3PT. weight limits #7
I agree.. they look real low. At those #'s.. i don't see how it can use most standard 3p implements. My little yanmar 1700 totes a 30" dirt scoop, and I know it must weight at least 200#.. maybee 225#.. I can lift it filled with dirt.. heaped over.. and I'm guessing total weight is nearing 750+ #.. all I need is front weight.. lift don't even groan at all.. yanks the scoop right up.. and that is a little ~19hp tractor
soundguy
/ 3PT. weight limits #9
Well.. that certaintly changes everything..
soundguy
/ 3PT. weight limits #10
My B7500 3 pt capacity was 1100# if my memory serves, it been a few years since i sold it.
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
(10) John Deere Tractor Weights (A64119)
(10) John Deere...
PALLET OF MISC METAL (A63291)
PALLET OF MISC...
2016 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 MACK CXU613...
