3PT Trailer Hitch
/ 3PT Trailer Hitch #1
coreshot
Utah
Kubota BX24
I had an old receiver hitch off of one of my trucks laying around, so I cut it up and turned it into a trailer hitch for the Kubota. I'm thinking with a little extra trussing, I can build a small subsoiler that will slip in the hitch. I basically plan on running electrical wire into the ground with the subsoiler, so it doesn't need to be too big, just to get the wire deep enough. Thoughts?
/ 3PT Trailer Hitch
Forgot the pics, duh...
/ 3PT Trailer Hitch #3
I did the same thing with a hitch off a Ford Explorer. Works great. You are right though about the extra trussing for ground engagement. I pull shrubs with mine using a 3' chain and doing both a lift and pull at the same time and I am sure without the extra trussing I would have broken it.
Chris
/ 3PT Trailer Hitch #4
Building one was one of my first projects after getting my welder. Can not believe how handy they are as far as pulling bushes, dragging logs around, pulling vehicles out of the mud, you can even move trailers with them.
/ 3PT Trailer Hitch #5
Here is some pictures of mine:
/ 3PT Trailer Hitch
I like that Kenny, pretty much exactly what I was thinking. What did you use for your tooth, looks like one out of a BB?
/ 3PT Trailer Hitch #8
I also built mine out of a hitch from a 3/4 ton truck. I flipped it over to gain a little extra height with my last tractor. This tractor is just enough higher that I am thinking of flipping it back right side up. Maybe I'll paint it then too:D
/ 3PT Trailer Hitch #9
Bingo:thumbsup: It's a replacement ripper tooth for a KK box blade from TSC.
/ 3PT Trailer Hitch
Nice. Tell me how effective the unit is in laying wire underground. How deep will it go? I have several hundred feet of runs I need to make, and this unit would save me a ton of time on the BH.
/ 3PT Trailer Hitch #11
It worked very well for me. Depth was about 12" to 14" or so...I made "dry" runs first to ensure the ground was softer and no obstructions such as large rocks or roots where in the way before loading the cable. There are quite a few other threads about those things-with some better ideas than I had used.
What do you want to bury?
/ 3PT Trailer Hitch
Mainly just electrical, I on a generator at my property and have extension cords above ground running to all the trailers and such. I just want to clean things up and put everything underground. If it works out ok, I may try to run some half inch water line.
/ 3PT Trailer Hitch #13
I have seen a thread a while back when someone put down plastic conduit or waterpipe in the same way. He did 50 or so foot runs and then pulled the wire into the conduit with fishing tape. Same idea as KennyD with steel pipe connected to a subsoiler and the conduit layed down through that.
/ 3PT Trailer Hitch
That would be nice, it would save some money on wire if I was able to buy the stuff that requires conduit.
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
Ford F-450 (A63689)
Ford F-450 (A63689)
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
FREIGHTLINER GRAIN TRUCK (A63291)
FREIGHTLINER GRAIN...
2007 Cadillac DTS (A61574)
2007 Cadillac DTS...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
