3point down pressure
/ 3point down pressure #1
fuseboxer
Gaines, Michigan
two john deere Sabres (2554-Scotts) and 4410 john deere ,Allis Chalmers WD , 5' Cub Cadet Zero turn
I bought a used John Deere 4410 and assumed it was a modern machine that had downward hydrolic power on the three point. I sold an old poor mans Deere an 880 Oliver and it had about 4000lb down or up. Is mine broke or do all JD4410 have no 3-point down power. The Oliver could pick up the rear tires with a garden box or blade etc. attached. --fuseboxer
/ 3point down pressure #2
I don't know of any makes or models of compact tractor that has down pressure on the 3 point..
/ 3point down pressure #3
Most newer units including the 4410 will not have down pressure on the 3 point hitch.
Hope this helps.
/ 3point down pressure #4
The Belarus Russian tractor had down pressure. Not any current production tractors, that I can think of does have? Ken Sweet
I am shocked that it does not have the ability to lift the back tires off the ground. The engineering design was there 50 years ago.
/ 3point down pressure #6
I bet it didn't pull very well that way! :)
Several times I wish I had down pressure to force a scarifier under a rock, etc.
Bruce
/ 3point down pressure #7
Many of those old tractors just used a hydraulic cylinder to raise and lower. Not much tech about that. Tech is using 3 point with draft control to make the implement take the ground. Many of the new CUTS dont have that feature. All should have. Ken Sweet
/ 3point down pressure #8
My 56 IH Utility 300 did have down pressure and would lift the rear (with loaded tires) off the ground...it was handy for putting on the Canadian Chains.
/ 3point down pressure #9
What did you do for draft control when plowing? Ken Sweet
/ 3point down pressure #10
That particular tractor spent most of its life in the woods....
/ 3point down pressure #11
WOW Iv been workin on tractors at a jd dealership for almost 15 years now and have never even thought of a 3pt hitch havin down psi!!!!!!!!!!. cool idea never seen it . I guess a simple hitch with a doubl acting cyl could do it. but no normal rockshaft type hitch could do it.:confused:
/ 3point down pressure #12
BTW....the IH U 300 I mentioned earlier had a 2 pt fast hitch (did have a insert to make it 3 pt....attached is a photo I found on the web...doesn't look exactly like mine but I did sell it over 25 years ago...and my memory may be a bit fuzzy
/ 3point down pressure #13
The engineering is pretty simple. But not needed or wanted in most 3 point hitch applications. The implement usally needs the ability to float... not be rock solild. Solid hitch would be a nightmare when plowing, etc on uneven ground.
Why do you need down pressure anyway? Just curious.
540' road to the orchard is only clay throught the woods. With down pressure I could push down and cut and level w/o putting on the garden box. Lazy man, also I am missing a bolt on one of the back wheels and the alignment is slightly off. I used a floor jack and loosened the bolts to try to get a few mm movement to get the bolt in but failed. I believe the back tires may be heavier than I want to wrestle with, probably loaded. I have a quick hitch that has never been on a tractor and may try it but I have too many other more pressing house to do jobs. If I could set the height of a blade or gardenbox and not float I could level out the crushed limestone pad approx 80' x 80' and 18" thick. A good tractor man could do it but for me I do a poor job. Without a 3' contractor rake it would not look as good as it does. I finish and start again because of a low spot that catches water. ---Fuseboxer
The deluxe feature of a large 880 Oliver includes a switch to have down pressure or turn off the switch and it floats. Fusebuster
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
UNUSED JCT 2 PRONG BALE SPEAR (A65055)
UNUSED JCT 2 PRONG...
2008 Ledwell LW48HTHT2 48ft. 40 Ton Hydratail T/A Step Deck Trailer (A64194)
2008 Ledwell...
UNUSED FUTURE D680 HYD PILE HAMMER (A65055)
UNUSED FUTURE D680...
2018 CATERPILLAR CB66B DOUBLE DRUM ROLLER (A65053)
2018 CATERPILLAR...
2001 FREIGHTLINER FL80 6X4 T/A VACUUM TRUCK (A67148)
2001 FREIGHTLINER...
