LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,711
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Well..... all I have is my box blade at the moment. LOL. Hopefully a LPGS, and a flail mower, maybe an old school draw bar drag disc.
That Pat's system looks real nice. I like the simplicity of it.
I thank you all for the input. What I did real quick to try out was use the Cat 2-3 bushing one the outside mounts, then a Cat 2 shaft collar on the inside as a thick spacer to keep everything from moving around. Kinda spaced everything nice and equal. Seemed to work okay as I was scraping... There's about an 1/8" play on each side, is that adequate?
...should be okay, no...??
Have you tried using the inner mounting tab? That looks like it can be used on a cat 2 or cat 3 tractor.
If you measure the widths does the outer mounting equal cat 3 width and the inner cat 2?
Also contributing to this is the angle of the arms in the outer location moved in they will be squared up more.
