354LE 4WD PROBLEM
   / 354LE 4WD PROBLEM #1
pej2945
Tennessee
Jinma 284 & Jinma 354LE
I have a new 354LE that appears to be stuck between 4WD and 2WD. I put it up on block stands to see if taking the pressure off all four wheels would help. But it only grinds when I put it in gear. The handle will move about 1 or 2 inches but will never catch and it appear to go in and out of 4WD and 2WD when I put pressure on the handle but if I release it only turns the back wheels and make a grinding sound. I have 14 hours and the tractor and the dealer said he only warrantees the engine for 6 months and anything else is my problem. Any suggestions would be appreciated :(
   / 354LE 4WD PROBLEM #2
If you look in your book on page 24 it will show you whats inside the cover.Things to check would be #2 Swell pin broken,# 11 bent shift fork,or # 14 needs lubrication.Should not be hard to fix.
Tommy
Affordable Tractor Sales
   / 354LE 4WD PROBLEM
Thanks Tommy, You’re a lifesaver, now all I need is a manual. I received a 284 manual with the tractor instead of the 354. I went home at lunch today and bungee corded the handle down and it ran without making any noise unless I tried to lift up on the handle and then it banged and grinded. Maybe it’s nothing serious. Thanks again for all your help!:)
   / 354LE 4WD PROBLEM #4
We have the manuals if you need to get one,unless your dealer is going to send you one.
Tommy
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
Misc Pallet of Gas Tanks, Transit Levels, Pumps, Bolt Pins (A57454)
Misc Pallet of Gas...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
Fencing (A56859)
Fencing (A56859)
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
