3520 - add 12V source
/ 3520 - add 12V source #1
tuolumne
Danby Vermont (soon)
I need a 12V source with a switch for a solenoid valve on a trailer. Are there spare spots in the stock fuse box on this machine? I do not have a cab. Any links to past threads for electrical modifications would be helpful.
/ 3520 - add 12V source #2
make your own derect from battery , with inlien fuse/circut bracker to a switch?
/ 3520 - add 12V source #3
I found two blank spots in the fuse box, one with constant power and one with power only when the tractor is on. The latter is perfect. How do I connect a wire into the back of the fuse box? Any particular connector needed? I can pick up a ground at the back of the tractor, so only one wire is needed.
/ 3520 - add 12V source #5
I suggest you use the same attaching method as the other fuses. You'll probably have to pull the fuse box to do this.
I've never had my fuse box pulled, so I don't know what type connector is used. Might be a forked connector screwed tight to the fuse box...but that's a guess.
As far as running the hot wire...do protect it somehow. If you can bundle it with the wiring harness, great...if not, get some of that corrugated flexible plastic tubing. IIRC, it's $0.59 at NAPA. Use plenty of wire ties to secure it to the tractor.
/ 3520 - add 12V source #6
As Roy suggested earlier,I would consider using a relay.
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
210 Gallon Plastic Tank with Pump (A65640)
210 Gallon Plastic...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2020 WESTERN STAR  4900 TRI AXLE (A65643)
2020 WESTERN STAR...
