3520 - add 12V source
/ 3520 - add 12V source #1
tuolumne
Gold Member
Danby Vermont (soon)
I need a 12V source with a switch for a solenoid valve on a trailer. Are there spare spots in the stock fuse box on this machine? I do not have a cab. Any links to past threads for electrical modifications would be helpful.
/ 3520 - add 12V source #2
make your own derect from battery , with inlien fuse/circut bracker to a switch?
/ 3520 - add 12V source #3
I found two blank spots in the fuse box, one with constant power and one with power only when the tractor is on. The latter is perfect. How do I connect a wire into the back of the fuse box? Any particular connector needed? I can pick up a ground at the back of the tractor, so only one wire is needed.
/ 3520 - add 12V source #5
I suggest you use the same attaching method as the other fuses. You'll probably have to pull the fuse box to do this.
I've never had my fuse box pulled, so I don't know what type connector is used. Might be a forked connector screwed tight to the fuse box...but that's a guess.
As far as running the hot wire...do protect it somehow. If you can bundle it with the wiring harness, great...if not, get some of that corrugated flexible plastic tubing. IIRC, it's $0.59 at NAPA. Use plenty of wire ties to secure it to the tractor.
/ 3520 - add 12V source #6
As Roy suggested earlier,I would consider using a relay.
2024 High Country Cargo 6x12 Enclosed Trailer, VIN#7FWBE1217R1035595 (A61166)
2024 High Country...
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
2011 Ford Ranger Ext. Cab Pickup Truck (A61568)
2011 Ford Ranger...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2001 KUBOTA R520 BACKHOE (A62129)
2001 KUBOTA R520...
