3520 - add 12V source
/ 3520 - add 12V source #1
tuolumne
Danby Vermont (soon)
I need a 12V source with a switch for a solenoid valve on a trailer. Are there spare spots in the stock fuse box on this machine? I do not have a cab. Any links to past threads for electrical modifications would be helpful.
/ 3520 - add 12V source #2
make your own derect from battery , with inlien fuse/circut bracker to a switch?
/ 3520 - add 12V source #3
I found two blank spots in the fuse box, one with constant power and one with power only when the tractor is on. The latter is perfect. How do I connect a wire into the back of the fuse box? Any particular connector needed? I can pick up a ground at the back of the tractor, so only one wire is needed.
/ 3520 - add 12V source #5
I suggest you use the same attaching method as the other fuses. You'll probably have to pull the fuse box to do this.
I've never had my fuse box pulled, so I don't know what type connector is used. Might be a forked connector screwed tight to the fuse box...but that's a guess.
As far as running the hot wire...do protect it somehow. If you can bundle it with the wiring harness, great...if not, get some of that corrugated flexible plastic tubing. IIRC, it's $0.59 at NAPA. Use plenty of wire ties to secure it to the tractor.
/ 3520 - add 12V source #6
As Roy suggested earlier,I would consider using a relay.
2015 Gehl V270 w/ Bucket (A63688)
2015 Gehl V270 w/...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
CrusterBuster 4000 Grain Drill (A63688)
CrusterBuster 4000...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
