336D injectors
/ 336D injectors #101
If it was carbon/dirt/rust like Bruce said earlier something stuck under a valve is very possible even on a clean new assembly. Air cleaner tubing etc can release this stuff anything before the valve and sometimes takes a bit of running to clear it out.
I'm not going to put dirty intake on a new Head. Esp. with so Much or Large enough Crap that it will Prevent a Valve from seating. :ashamed: That would be like reuseing the Old Dirty Air Filter. If the head came from a Used Parts or a Junk Yard and put on without even cleaning or going through it I could understand but thats not the case. Never had it happen with everything cleaned and installed properly.
/ 336D injectors #102
I have seen it a lot of times nobody is perfect 100% of the time dont care who ya are. And remember he is on a re-do the stress is worse the second time around makes missing some little thing easier. Every time you take something apart you have the opportunity to stir it up. :thumbsup:
for instance I see mass air flow sensors get dirt and fuzz in them quite often from someone simply changing filters and letting a chunk of dirt or debris loose from around the filters seal and that turns the check engine lite on - po171 its common.
I personally let a metal mass air flow meter mounting bushing spacer loose into a 280z intake one time when I was replacing the vane type meter. And it went clear into the cylinder, I had to drill the plug hole and fish the chunk out and install a helicoil plug repair insert to fix the car **** happens to all of us.
/ 336D injectors #103
This is a basic diesel Eng. Not a 280 You Couldn't give me straight six pos. and back to your error of not installing it properly. Happened to me alot of times also that how you learn what not to do. My bet it hasn't happened again ;)
/ 336D injectors
I called the machine shop just to make sure they checked the head for cracks - they do and the vacumn check the valves to make sure they are sealed. He seems to think I bent a valve. I will compression check it this evening.
/ 336D injectors #105
This is a basic diesel Eng. My bet it hasn't happened again ;)
Same exact thing complex or simple engine they operate exactly the same on the same 4 cycle principles no matter how much electronics etc you hang on the outside same inside.
And no I never let anything into an engine since but that also proved I will never be 100% perfect.
edit: Actually I take that back I occasionally break carbon loose into cyl's when changing spark plugs and stick exhaust valves open.That clears up by road testing them or revving the pee out of them a couple times in the shop but no one has a way of knowing that is going to happen it just does.
/ 336D injectors #106
This is a long thread but I believe at the beginning there was a bent push rod. I'm wondering now if it would be possible your cam shaft is bent or twisted. Just putting something out there for thought.
/ 336D injectors #107
Thought of that also Winston. But with it being intermittent and doesn't have Hyd.Lifters it's doubtful. My Guess still in the head. Valve or valve guide. Still just a guess.
/ 336D injectors #108
That would be my luck and sure it happens. I have a 01 5.4 that developed spark Knock at around 35000 on the clock. Don't turn wrenches much anymore and new there was a problem with carbon on the plugs on it even now a days. Under warrenty that and a vibration in the Dr.shaft being a long bed. I new it and thats why they gave me a rental for a couple of days while they soaked the plugs just to be safe ;)
/ 336D injectors #109
I just have a problem with the brand new bent valve it doesn't add up in my mind.
If it is a bent valve there is something else at play here what that is is anyone's guess at this point.
I still worry about the comp release adjustments etc that is the only thing that could put an exhaust valve in close enough proximity to a piston to bend 2 in a row!!!
/ 336D injectors
How about operator error!!! I checked the compression on the middle cylinder 405lbs. check the rear - not enough to pump up the gage... pulled off the valve cover and the lifters were tight. re adjusted the lifters and 410 on the front and rear cylinders.
I re torgued the head bolts and forgot to re adjust the valves. I am such an idiot.
Ran it for 20 mins and this is what it sounds like -
Feb 27, 2012 3:00pm | Facebook
I really appreciate all your help and patents and hope I have finally got it figured out.
/ 336D injectors #112
Good for you. sounds Great. Sure enough it was in the valves.:cool:
/ 336D injectors #113
Great!
Not even going to tell you what I really think this is a family forum ;)
/ 336D injectors #114
Hurray, Hurray, love a good ending. :thumbsup: :thumbsup: :thumbsup:
/ 336D injectors #115
AWESOME! Glad it was something simple. Looks like you are back in action. Good for another 1000 hours without a sweat. Now what projects to use it on?
/ 336D injectors
Thanks everyone
Project to use it on is 24 acres to clear the logging trails to plant food plots.
/ 336D injectors #117
Vern said:
Thanks everyone
I thought you were almost there. Congradulations!
/ 336D injectors #118
thats a sweet sound for sure, Glad its back in action !!
You knew it had to be something simple.....
/ 336D injectors
Had the tractor out to the camp this weekend. it was about 35 degrees and it was hard starting. Loaded on the trailer and road great - 18' duel axle. Almost didn't start to unload but ran great while I cleared and area to park the rv. Sunday morning had a dead battery - would barley turn over and had to run to town to get jumper cables. It was cold so it was a bit hard starting again. I worked it pretty hard for about 3 hours - what ever machine they use to strip the banches off the trees tangles them up pretty good. Best I could do is get the bucket to roll the stuff - have to make a brush fork.
Stopped for lunch and it was still a low battery again but it did start. Got it on the trailer and was not satisfied with the location and tried to start again - dead battery.
Got home and put the charger on - it charged up and tractor started - I am getting 13 1/2 volts to the battery with nothing really drawing other than the starter
Anyone run into this?
Tractor ran great - had some lifter noise so will re check them.
/ 336D injectors #120
Glad to hear she is running good! I dont think 13.2v is enough even if its got a good battery but I suspect the battery is bad since the tractor doesn't draw any power unless the lights are on but thats my guess.
2022 EZ-GO ELITE...
2000 SHOP TANDEM AXLE TRANSPORT TRAILER (A65643)
2000 SHOP TANDEM...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2018 DODGE RAM 2500 (A65643)
2018 DODGE RAM...
2018 FREIGHTLINER CASCADIA 125 6X4 T/S SLEEPER TRUCK TRACTOR (A67147)
2018 FREIGHTLINER...
