3205 fuel pump?
/ 3205 fuel pump? #8
It is.
I'm leaning towards the Facet FEP4SV american made too.
Well it looks like it should work. From the internet: Facet FEP04SV Posi-Flo Electric Fuel Pump 1.5-4 Psi
I see that the Kawasaki shop manual specs fuel pressure out of the pump at 2.76 psi minimum.
Richard
/ 3205 fuel pump?
Richard
Richard001, there is also napa bk6102001 (facet 40288) with a 3-4.5 psi spec.
Which would U do?
I don't want to be pushing past the needle&seat, but also don't wanna starve it either.
Thanks
/ 3205 fuel pump? #11
Well I don't know. You could try to contact someone at Kawasaki and ask what the max fuel pump pressure they recommend, but I doubt very much if you will get a response.
The other thing you could try is to contact Facet and ask if they think this pump will work with a small engine.
Richard
/ 3205 fuel pump?
Richard
Thank You for the facet idea.
/ 3205 fuel pump? #13
Buy the pump. If it is too strong, do what Seadoo two stroke engines have, a small line back to the tank. Such as a Tee in the supply line with a tiny hole in the branch of the tee. An orifice which bleeds a small amount that the carb does not need.
Dave M7040
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63689)
2012 Ford F-150...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
