3205 fuel pump?
/ 3205 fuel pump? #8
It is.
I'm leaning towards the Facet FEP4SV american made too.
Well it looks like it should work. From the internet: Facet FEP04SV Posi-Flo Electric Fuel Pump 1.5-4 Psi
I see that the Kawasaki shop manual specs fuel pressure out of the pump at 2.76 psi minimum.
Richard
/ 3205 fuel pump?
Richard
Richard001, there is also napa bk6102001 (facet 40288) with a 3-4.5 psi spec.
Which would U do?
I don't want to be pushing past the needle&seat, but also don't wanna starve it either.
Thanks
/ 3205 fuel pump? #11
Well I don't know. You could try to contact someone at Kawasaki and ask what the max fuel pump pressure they recommend, but I doubt very much if you will get a response.
The other thing you could try is to contact Facet and ask if they think this pump will work with a small engine.
Richard
/ 3205 fuel pump?
Richard
Thank You for the facet idea.
/ 3205 fuel pump? #13
Buy the pump. If it is too strong, do what Seadoo two stroke engines have, a small line back to the tank. Such as a Tee in the supply line with a tiny hole in the branch of the tee. An orifice which bleeds a small amount that the carb does not need.
Dave M7040
Frontier RT3062 (A64126)
Frontier RT3062...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
2022 Ram 3500 Hauler Truck, VIN # 3C7WRTCLXNG270348 (A65563)
2022 Ram 3500...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
8ft. Metal Drag (A65640)
8ft. Metal Drag...
