3205 fuel pump?
/ 3205 fuel pump? #8
It is.
I'm leaning towards the Facet FEP4SV american made too.
Well it looks like it should work. From the internet: Facet FEP04SV Posi-Flo Electric Fuel Pump 1.5-4 Psi
I see that the Kawasaki shop manual specs fuel pressure out of the pump at 2.76 psi minimum.
Richard
/ 3205 fuel pump?
Richard
Richard001, there is also napa bk6102001 (facet 40288) with a 3-4.5 psi spec.
Which would U do?
I don't want to be pushing past the needle&seat, but also don't wanna starve it either.
Thanks
/ 3205 fuel pump? #11
Well I don't know. You could try to contact someone at Kawasaki and ask what the max fuel pump pressure they recommend, but I doubt very much if you will get a response.
The other thing you could try is to contact Facet and ask if they think this pump will work with a small engine.
Richard
/ 3205 fuel pump?
Richard
Thank You for the facet idea.
/ 3205 fuel pump? #13
Buy the pump. If it is too strong, do what Seadoo two stroke engines have, a small line back to the tank. Such as a Tee in the supply line with a tiny hole in the branch of the tee. An orifice which bleeds a small amount that the carb does not need.
Dave M7040
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
2022 HAULMARK 14' T/A ENCLOSED TRAILER (A65643)
2022 HAULMARK 14'...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
