3205 fuel pump?
/ 3205 fuel pump? #8
It is.
I'm leaning towards the Facet FEP4SV american made too.
Well it looks like it should work. From the internet: Facet FEP04SV Posi-Flo Electric Fuel Pump 1.5-4 Psi
I see that the Kawasaki shop manual specs fuel pressure out of the pump at 2.76 psi minimum.
Richard
/ 3205 fuel pump?
Richard
Richard001, there is also napa bk6102001 (facet 40288) with a 3-4.5 psi spec.
Which would U do?
I don't want to be pushing past the needle&seat, but also don't wanna starve it either.
Thanks
/ 3205 fuel pump? #11
Well I don't know. You could try to contact someone at Kawasaki and ask what the max fuel pump pressure they recommend, but I doubt very much if you will get a response.
The other thing you could try is to contact Facet and ask if they think this pump will work with a small engine.
Richard
/ 3205 fuel pump?
Richard
Thank You for the facet idea.
/ 3205 fuel pump? #13
Buy the pump. If it is too strong, do what Seadoo two stroke engines have, a small line back to the tank. Such as a Tee in the supply line with a tiny hole in the branch of the tee. An orifice which bleeds a small amount that the carb does not need.
Dave M7040
2024 SILVERBACK 53CH3A TRI/A CAR TRAILER (A59914)
2024 SILVERBACK...
KOMATSU PC88MR-11 EXCAVATOR (A65053)
KOMATSU PC88MR-11...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
HD Bale Ring (A66408)
Landhonor Quick Attach Hydraulic Forks (A66285)
Landhonor Quick...
