3205 fuel pump?
/ 3205 fuel pump? #8
It is.
I'm leaning towards the Facet FEP4SV american made too.
Well it looks like it should work. From the internet: Facet FEP04SV Posi-Flo Electric Fuel Pump 1.5-4 Psi
I see that the Kawasaki shop manual specs fuel pressure out of the pump at 2.76 psi minimum.
Richard
/ 3205 fuel pump?
Richard
Richard001, there is also napa bk6102001 (facet 40288) with a 3-4.5 psi spec.
Which would U do?
I don't want to be pushing past the needle&seat, but also don't wanna starve it either.
Thanks
/ 3205 fuel pump? #11
Well I don't know. You could try to contact someone at Kawasaki and ask what the max fuel pump pressure they recommend, but I doubt very much if you will get a response.
The other thing you could try is to contact Facet and ask if they think this pump will work with a small engine.
Richard
/ 3205 fuel pump?
Richard
Thank You for the facet idea.
/ 3205 fuel pump? #13
Buy the pump. If it is too strong, do what Seadoo two stroke engines have, a small line back to the tank. Such as a Tee in the supply line with a tiny hole in the branch of the tee. An orifice which bleeds a small amount that the carb does not need.
Dave M7040
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
Bush Hog 3008 (A64127)
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
Quick Attach Snow Push (A66408)
Quick Attach Snow...
72" JCT TILLER (A62613)
72" JCT TILLER...
