3038E Speedometer
/ 3038E Speedometer #1
stevieray36
Oklahoma City
John Deere 3032E
I recently purchased a new 3038E and just noticed it does not display vehicle speed or mph. The manual doesn't cover speedometer and I have called the dealer and John Deere with no luck. I am told the 3038R has a speedometer. How are you to apply fertilizer and use a sprayer without ground speed? The tractor is hydrostatic so the ground speed charts do not apply.
/ 3038E Speedometer #2
Google "Measuring tractor ground speed for fertilizer spreading" and some hits will give you some ways.. For hydrostatic, use a set rpm and cruise control over a measured course for distance, while monitoring the volume or weight of the fertilizer at a setting. Calculate from there.
Maybe will take a few trial runs..
There are, I believe, monitors that are available as well and maybe can be rented or borrowed from a fertilizer farm store.
/ 3038E Speedometer #3
I have a hand held Garmin GPS I used to calibrate the speed odometer on my Honda motor cycle. It wasn't real expensive. Worked excellent. Hope this helps.
/ 3038E Speedometer #4
I had this exact same question and the solution in this post is what I did. Ordered and installed a cruise control kit. Part of calibrating your sprayer nozzles (or actually measuring nozzle output) involves running and timing a predetermined distance. I now set my RPMs where I know it's supposed to be and mash the go pedal all the way to the floorboard and lock in the cruise control.
/ 3038E Speedometer
What was John Deere thinking when they redesigned the 3000 series tractors?
There is no speedometer, wheel base is 8 inches shorter and the the vehicle weight is over 600 lbs lighter than my 3203 John Deere. Should have done better research and I would not have purchased a new 3000 series John Deere.
/ 3038E Speedometer #6
My 3039R has a speedometer (can't speak one way or the other about the E). Not sure what the heck I need it for, but it's there all the time.
As for the rest, I'm really liking my 3000 series just fine, thank you. I move all kinds of heavy stuff with it super fast, super reliable, and safe as can be. Hard to ask for more in my opinion.
AIR COMPRESSOR 3-PHASE (A67714)
AIR COMPRESSOR...
Generac SD135 136kVA Standby Diesel Generator (A66734)
Generac SD135...
2020 INTERNATIONAL MV607 REEFER (A67714)
2020 INTERNATIONAL...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
Gravely Pro-Turn 148 50in Zero Turn Commercial Mower (A66734)
Gravely Pro-Turn...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
