3020 SCV coupler conversion
/ 3020 SCV coupler conversion #1
Harry in Ky
Elite Member
Winchester Ky
Allis Chalmers ED 40
So how much fun is it to remove the JD coupler cartridges and install the Pioneer type? This tractor has one 20 series coupler body and one 10 series body. Is the procedure pretty much the same for both types?
/ 3020 SCV coupler conversion #2
Just match the threads, If I understand correctly what you want to do.
No, I guess you don't. I'm talking about the cartridges in the coupler bodies. There's a bit more to it than matching threads.
/ 3020 SCV coupler conversion #4
What is the part number? You can find it in jdparts.com.
/ 3020 SCV coupler conversion #5
I'm not aware of a conversion for 10 series couplers or 20 series couplers on pre- side console tractors ( up to 1969).
/ 3020 SCV coupler conversion #6
There are ISO kits for both 10 & 20 rear breakaway couplers. This is the part number for kit for 20 series RE206778 Quick Coupler Kit - QUICK COUPLER KIT, RECEPTACLE KIT 146.70 USD. Kit part number for 10 series is the same plus some other extra parts. IMHO the spiral back up washers(parts key 20) are a PITA to install correctly.
The man said he has the kits. I'm just wondering what does it entail to put them in?
/ 3020 SCV coupler conversion #8
IMHO all that's required for kit installation is mechanical ability & PATIENCE.
Okay, that sounds reasonable. I just didn't want to spend an hour on the road, only to find it requires a press, or some specialty gadget or two that's not available out there.
Thanks
/ 3020 SCV coupler conversion #10
Harry
I think the kit can be field installed but it's been a long time since I was a service manager
/ 3020 SCV coupler conversion #11
Aren't there adapters you can install (just like a hose end) then an ISO hose end connects? At TSC maybe?
/ 3020 SCV coupler conversion #12
Zebrafive
You mean similar to these.
/ 3020 SCV coupler conversion #13
YES! Accomplish the same thing at much lower cost
Already suggested that. The man wants the cartridges changed.
/ 3020 SCV coupler conversion #15
Often the change to ISO coupler barrels is driven by the reality that the original cone style couplers are worn out and leaking.
2012 JACK CO 130BBL VACUUM TRAILER (A67714)
2012 JACK CO...
2018 CHEVROLET 3500 SILVERADO CREW CAB PICKUP TRUCK (A66091)
2018 CHEVROLET...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
2018 JOHN DEERE 320G SKID STEER (A65056)
2018 JOHN DEERE...
2013 John Deere 544K Articulated Wheel Loader (A66734)
2013 John Deere...
2014 FORD F-150 (A67714)
2014 FORD F-150...
