3020 3 point hitch
/ 3020 3 point hitch #1
Draagyn
Woodpecker, Canada
65 JD 3020, 75 IH 966
This is my first tractor so I'm not sure on how this should be operating. The cable between my dash lever and valve lever for the raise/lower 3 point did not come with tractor. To raise and lower it I just use the valve lever. The problem I'm having is it always goes up and down super fast and is hard to stop it in a halfway position, which I should be able to do right?
So far all I've used it for is my post pounder and I have to raise it up to put it on its stand. The rest of the time it operates in the fully down position so it's not an issue. Sometimes I can get it to stay halfway up but usually creeps so I just shut tractor off and put valve in full up position.
Right now I'm gearing up to cut my own hay and I've been avoiding 3 point rake for this reason.
My main question is: If I got a new cable would I have finer adjustment of the valve to get it to stay where I want it or is it a bigger problem?
Thanks
/ 3020 3 point hitch #2
Is the L/D lever under seat set in "D"? Probably not. If it is in "D" then L/D mechanism needs adjusting as outlined in a JD 3020 tech manual.
Thanks Jim! Looks like that was all it was. Didn't know that would effect that part of operation. Thanks again!
2020 John Deere 560R Premium Round Baler (A63111)
2020 John Deere...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
2002 Schulte XH1500 15ft. Batwing Rotary Brush Cutter Tractor Attachment (A61572)
2002 Schulte...
Precison Planting Air Compressor (A63117)
Precison Planting...
