3020 3 point hitch
/ 3020 3 point hitch #1
Draagyn
Woodpecker, Canada
65 JD 3020, 75 IH 966
This is my first tractor so I'm not sure on how this should be operating. The cable between my dash lever and valve lever for the raise/lower 3 point did not come with tractor. To raise and lower it I just use the valve lever. The problem I'm having is it always goes up and down super fast and is hard to stop it in a halfway position, which I should be able to do right?
So far all I've used it for is my post pounder and I have to raise it up to put it on its stand. The rest of the time it operates in the fully down position so it's not an issue. Sometimes I can get it to stay halfway up but usually creeps so I just shut tractor off and put valve in full up position.
Right now I'm gearing up to cut my own hay and I've been avoiding 3 point rake for this reason.
My main question is: If I got a new cable would I have finer adjustment of the valve to get it to stay where I want it or is it a bigger problem?
/ 3020 3 point hitch #2
Is the L/D lever under seat set in "D"? Probably not. If it is in "D" then L/D mechanism needs adjusting as outlined in a JD 3020 tech manual.
Thanks Jim! Looks like that was all it was. Didn't know that would effect that part of operation. Thanks again!
2016 FREIGHTLINER CORONADO 122 SD (A67714)
2016 FREIGHTLINER...
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
Unused 2022 HLA 60in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
2021 Jeep Gladiator 4x4 Crew Cab Pickup Truck (A66736)
2021 Jeep...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A67714)
2013 POLAR TANK...
2011 HUTCHISON CRUDE TRAILER (A67714)
2011 HUTCHISON...
