3016 HST. Enough HP?
/ 3016 HST. Enough HP? #41
Nothing unfortunate about it. You will be very happy with the 3016. I am. And I work it hard.
/ 3016 HST. Enough HP? #42
That's probably the way I would've went. It's easy to get caught up in the more horsepower merry-go-round. It sounds like a great set up. I've never used a sickle mower before but I'll bet it will be very handy. I'd be interested to know how it works out for you if you get it and let us know what you think of the new machine after you've had a chance to try it out with some of the attachments. Now all you have to do is try to patiently wait for delivery.
/ 3016 HST. Enough HP? #43
Unfortunately, I signed the contract on the 3016 before the last set of replies. I just couldn't swing the extra $4500 for the 3616 ($4k plus freight), or the $5500 for the 1533. Hopefully I won't be too disappointed.
I bought a 5' Mahindra (Kodiak) tiller, SS forks, 5' rotary cutter, and Rim guard ballast. It has a grill guard standard as well as R4 tires.
Based on all your responses, I will call the dealer in the morning and have him order me the rear remote kit. I may have him install it only so it is covered under mfg warranty. My wife found a hydraulic-lift sickle mower she wants.
D, don't have any apprehensions with what you get here. It is a bunch of assessments and opinions that alter greatly from person to person. I have ags and wish for the R4's as I rut my grass something terrible. If you ever need more traction, R4's with chains are a game changer. Old Pilgrim loves his hst as do a bunch of people on this forum. As you learn the tractor, you'll get more and more proficient with it. If it ends up just what you want, keep it. If not, save some shackles and in 3 or 4 years trade it in. You're never stuck. Life's a beach.
/ 3016 HST. Enough HP? #44
I've had a 3016 shuttle for three years and it's done everything I've asked of it. The only time I've wished for a 3616 was this spring. With all the rain we got this spring the Bahia that I have to mow got incredibly thick. I had to slow way down in a few spots and I think the extra 8 horsepower on a 3616 would have allowed me to do the job more quickly. As to any other jobs I've asked of it, including pulling heavy trees, it's done a great job. I went with the shuttle because it has more PTO horsepower than the HST. I don't think you'll be disappointed in your choice.
/ 3016 HST. Enough HP? #45
IMHO,
Given 65 Acres, you need a larger frame, more powerful machine, just one size up from what you are considering.
/ 3016 HST. Enough HP? #46
IMHO,
/ 3016 HST. Enough HP? #47
The rear remote can be installed by removing the seat and the plastic cover panel on the inside of the fender. Not that big of a deal. If your dealer is willing to sell it to you for $850, get it, that is a deal. This valve also has the float function with it, it is a good clean setup. If you think that you will ever need more than one remote, then forget about it and just go aftermarket. Mahindra only offers a single rear remote option for their 16 series tractors. Morons :sigh:
People always seem to say that the lower HP models will do the same work as the higher HP models and for the most part they are right. What the main difference is, is the speed that the job can be done with the higher HP model. This applies to most all types of work, not just PTO work. Example, your pulling a loaded box blade up hill. 30 HP tractor is struggling but not breaking traction and getting the job done. The 36 HP tractor does the same, except does not struggle and can actually move along at a faster rate. So moving the same amount of material, just faster.
Just my :2cents:, I'm sure that you will be happy with either machine. :thumbsup:
What on earth would you be doing with a compact tractor to need two sets of remotes? There is a simple system made by Fasse that will turn you single set into a dual
/ 3016 HST. Enough HP? #48
You're joking right? Number one, that Fasse multiplier WILL NOT work on the Mahindra 3215 factory rear remote, been there done that. The swivel pieces that are suppose to allow you to plug into a single set do not get you enough adjustment to plug in.
Second, top and tilt cylinders for the 3pt hitch, there's 2, an angle cylinder for a rear blade or landscape rake, there's 3. Ever seen a rear blade that has 3-4 rear hydraulics on them? There would be 6. I current have 4, for top & tilt, angle and offset for my landscape rake and hope to purchase a Land Pride RBT3584 some day. I will use the angle and offset hydraulics on that also. ;)
/ 3016 HST. Enough HP? #49
Think of the percentage of people that use that type of equipment on a compact tractor though... In the last three years I can count on one hand how many compacts we have sold that was ordered with even one set of remotes.. all angle blades, top links, and rakes have been self adjust. Sold one for a trencher, one with a hay rake.... now third functions.. yeah plenty of those but its kinda pointless to keep a special set of remotes around when 95% of the people don't even use one set. Not saying it isn't the best way to go using hyd. but its not smart as a manufacture/business imo
Didn't know that about the Fasse and the 15 series remotes.. good info to have thank you!
/ 3016 HST. Enough HP? #50
A HUGE part of the hydraulic thing is education. Most people simply do not know about it. My experience is that a lot of dealers don't know-understand, so don't want to sell the stuff, plus it is costly. I have had dealers flat out tell me "why would I want to sell a top & tilt system to a customer that I have to charge $2000-$3000 ,when I can sell them multiple implements for that much money? The customer is better off with all the implements."
REALLY, so now ALL the 3pt adjustments have to be made manually and that ends up not being made at all after awhile. Everyone ends up with "that's good enough syndrome" simply because they are tired of the tiresome process that it is to make a manual adjustment. When if they had hydraulic adjustments, it takes fractions of a second and all they have to do is touch a lever with their finger tips.
Do people by cars without air conditioning, after all, you don't really need it do you? Think of the thousands of dollars cheaper that the cars could be sold for. But no, pretty much everyone understands the benefits of having air conditioning. Well, people (dealers and the customers) just need to be educated about hydraulic actuated adjustments and the extreme benefits that they can offer.
I bought my 3215 from Dave's Tractor, I'm sure that you know him, West coast Mahindra distributor. Sells A LOT OF TRACTORS. My 3215 was the first 15 series tractor that he had ever sold with the factory rear remote on it.
More that a few people must want this stuff, I'm currently running at a 9 week back log.
I hope that some of this benefits someone. ;)
/ 3016 HST. Enough HP? #51
This is the main issue for most of the customers... Most and i did say most people simply do not buy compact tractors and do enough work to justify it.. I sell plenty of Hyd. equipment that's not the issue.. we have every bit of it available to the customer. But im not going to stock something to sit on the lot and collect dust... however it can be ordered with no problem if that is the route the customer wants to go. Now loader hyd. equipment... its popular here so yes we keep plenty of it. All these stocking decisions are made off of past/present experiences.. we just aint shooting in tha dark
/ 3016 HST. Enough HP? #52
I have 2 rear remotes on my compact tractor for my hydraulic top link and tilt cylinders.
I can tell you after having top & tilt on my tractors 3 point for the past 14 years I will never own a tractor without it.
/ 3016 HST. Enough HP? #53
It's a "once you have it you don't want to ever go without it." How many cars have "crank" windows nowadays. Auto manufacturers found out a long time ago that "convenience is king"
/ 3016 HST. Enough HP? #56
Kodiak makes their bush hogs and box blades, rebranded for Mahindra. They lean towards Howse for their grooming mowers at least here in NC anyway.
I just got the Med. Duty 5 ft Kodiak thanks to some good info from some guys here on the forum. So far i'm happy with it. I got the box blade over 2 years ago and it's still going strong.
The pallet forks I got from Everything Attachments. Couldn't be happier with them. I use them more than the bucket most times.
I'lll second that on pallet forks... extremely handy. Mine are just the clamp on variety but they are surprisingly stout. I cleared out a corner of my acreage with downed limbs and trunks and never had to get off the tractor to move them to a burn pile. Wouldn't be without them.
Thanks for all the great comments and help. Our 3016HST was delivered last week. We did get the rear remote, pallet forks, rotary cutter, SS FEL, and tiller.
It drives like butter! We've put 15 hours on it already mostly mowing the pastures. It never ran short on power, even mowing steep hills with the 5' rotary cutter. I'm really impressed with the fuel economy - averaging 1.25 hours/gallon
Couple of questions, though:
The FEL is really smooth up/down, but jerky when tilting. Is there a 'best' rpm range that will smooth it out?
Is it normal for the FEL to drop over time? It seems that while mowing - a few times - I had to raise the bucket to keep it off the ground. We're talking over many hours.
Finally, my wife claims the cruise control slows down over time. I didn't use it, so I can't comment. She says she had to keep resetting it to maintain speed on level ground.
Thanks again for all the great assistance through this acquisition.
/ 3016 HST. Enough HP? #58
Congrats!!! I'm glad you are happy with it. Yes it is normal for your loader to drift down a little. as far as the jerky tilt I'm not sure maybe air in the line or it might take some getting used the controls to. If it is air normally if you just hold control lever all the way for about 20 seconds it can work its way out. The Cruise control sounds like a adjustment I would just give your dealer a call and see what he says.
/ 3016 HST. Enough HP? #59
I've been reading here & there to help with choosing a tractor for myself and the 3016 is what I have my eye on mainly because it can lift 1,600 lbs at the pins. What disappoints me is that the dealer only offers a single rear remote as an option. Where can I look to have multiple remotes I can install? I want a remote for the grapple & snow blade (angle) and two at the rear for box blade, rear blade leveling.
/ 3016 HST. Enough HP? #60
Aquamoose do you have a dealer near you with a 3016 still on the lot
Sent from my iPhone using TractorByNet
