3000 Series A/C Issues
/ 3000 Series A/C Issues #1
Silver_Knight
Marble Falls, TX
I have been having issues with the A/C on my 3720 which has about 70 hours on it. I took it into the shop for service and had them look at the A/C because it was just not cooling like it should. In the heat of the day 95 degrees with 60% humidity it would not cool below 80 degrees coming out of the vents. I stuck an AC thermometer in the vent and it would not get below 80. In the morning or when I clean the condenser with water it will get in the 60痴 but as soon as I get going again it gets right back up to 80.
I have cleaned the condenser many times. This is extremely difficult to clean because it is sandwiched between the radiator, Hydraulic oil cooler and the turbo cooler. You have the battery on the bottom part and the turbo cooler on the top part so there is really no where for air to go through.
Picked it up at the dealer who said he did the best he could which amounted to nothing. He said that JD just did not design the system to cool?which I agree. He said he was able to get it to cool to 70 degrees coming out of the vent in the afternoon but I tried it as soon as I got home and after an hour of riding around I felt he lied about that because it never went below 80.
I called a couple of other JD stores and spoke to the salesmen to see what they had to say about the AC on the 3000 series. They all said it worked 敵REAT? 笛UST LIKE YOUR CAR and 鉄O COLD YOU CAN HANG MEAT IN THE CAB? We値l friend that is a bunch of 笛DBS?
I知 here to tell you I致e spoke to two different JD service techs and they both have told me the 3000 series AC system does not work well at all.
I took my unit back to the JD service center and told him to do something to make it cool. I did not buy the [best] tractor built today to sit and sweat while watching guys in orange tractors drive buy with chill bumps!
He said he was going to install a small high volume fan on the front of the turbo cooler to push air through the condenser. He said it would be pretty loud but would probably work. We went back and forth a while because I did not want to have to put extra parts on my new tractor o make it work but finally gave in because that seemed like the only thing he could come up with.
Has anybody else had any issues with their 3000/4000 series not cooling and if so what was the fix?
Any ideas?
/ 3000 Series A/C Issues #2
Somebody else on TBN had problems w/ thier JD AC.
Guess it turned out to be major air leaks on the intake side of the evap.
/ 3000 Series A/C Issues #3
You need to get a different dealer to look at it. What he is saying just isn't true. I just had mine checked at a dealer 2 weeks ago. The temp at the vent when they checked it was 30F.
I bought mine in the fall of 2006, and in the winter had major problems with getting the engine to warm up or put out heat in the cab. After 5-6 trips to 2 different dealers, they found an air leak in the corner of the air box letting in cool air. You may have the same problem but notice it with cooling. Try putting a piece of plastic wrap over the filter in the back of the cab/airbox. The suran wrap should be sucked up tight to the filter if there is no air leak.
Make sure you don't have the heat control turned on with the A/C control. The two can be on at the same time and cancel each other. Try pinching the heater hose going to the cab with a piece of cloth and vise grip to be sure hot water isn't circulating even if the control is turned down. The inflow hose is one the left side by the loader arms and cab glass. You will see a connector in the hot water line hose. I removed the connector/splice and installed a radiator hose shut off valve. I turn the hose off in the spring to prevent any hot water flow to the cab air box.
The idea of a fan installation in front of the condensor is IMHO a waste of time and money. The system is designed to cool. The dealer just can't figure it out. I am very comfortable in my A/C cab on a 100F day.
If the compressor is working correctly with the proper pressure in the lines (this is easy to check with gauges), and the freon level is good, then look for outside air getting in the air box or hot water flowing through the heater core.
/ 3000 Series A/C Issues #4
I have a JD 3720 cab tractor purchased new about 14 mos ago. After about 90 hrs on the meter, I feel the the A/C and heating are both somewhat anemic, but I found the heater and A/C work best when running at rated RPM's. Consequently, I am always running at or very near rated RPM's with the A/C or heat controls turned up to max.
/ 3000 Series A/C Issues #5
It was about 88 degrees here today and very humid. I use my 3720 cab to bring some straw out to the garden, when I got there it was so nice and cold I didn't want to get out. One down side of having the cab! The things that I have notice affecting my ac performance are dirty cab filter and dirty condenser. I clean my cab filter probably every 10 hrs or so and the condenser and radiator get cleaned whenever I wash/hose down the tractor. I use an air compressor to clean the cab air filter and a garden hose to clean the condenser. I'm always amazed how much dirt is in the cab filter. It's maintenance that I found must be done to keep the ac working properly. Also when I did my radio install and had the roof off I fix a lot of tears and cracks in roof top seal. I was socked at how many there were! I had read previous threads that stated this was an issue that affected ac performance. Something to check anyway.
/ 3000 Series A/C Issues #6
Only thing I haven't done to my 3720 cab is to remove the roof and check for air leaks. Will do it one of these days when the weather is right, eg, 70-80 degrees. I do clean the filters and screens frequently as you mentioned. I guess I'm just plain spoiled by comparing with the heat and A/C in my larger orange tractor (M8200). Don't get me wrong, I do really like the JD 3720 for what I mostly use it for -- mowing 5 acres lawn, mowing hay fields, and blowing snow off 3000 foot driveway --- just a little disappointed with the anemic heat and A/C system.
My filter and condenser is clean. Actually the filter is brand new. My dealer said that if I taped up my filter it would create a recirculate mode. I tried that and did not notice any change at all so I took the tape off. So frustrating to buy the best and end up with stuff that doesn't work and dealer can't even make it work.
/ 3000 Series A/C Issues #8
Did you check the roof for gaps in the insulation? My 3520 get cold with AC on and hot will Heat on, and it works very well sofar.
/ 3000 Series A/C Issues #9
I would write a letter to John Deere Corp. Get them involved - it is not working to spec. It has been so hot lately, I would be pissed too.
What RPM are you running the engine?
Did it ever work well?
D.
/ 3000 Series A/C Issues #10
Get it checked by another dealer...when I got my tractor this spring I had them install the Radio Mount Kit & CD Player...when the popped the top they found the gasket to be torn and such...they warrantied it and installed a new gasket all the way around. The tech also told me if I needed to pop the top for any reason, if there was ANY Gaps, to put another gasket in as the roof to cab seal is imperative in having it blow hot or cold.
I can say even on the hottest/muggiest day this year, I've had to crank down the "Coolness" because it was getting cold in the cab....There is something wrong with your unit forsure.. "Best they can do" is obviously nothing...
/ 3000 Series A/C Issues #11
I've got a 3720 cab and the A/C works fine. I actually think the heat doesn't crank out as much as it should (not that I mind, I like it cool in the winter).
I haven't had too many 95 degree days but here in New England I've had many in the 90's last summer and maybe one so far this summer and a lot in the high 80's with high humidity. No problems. Last few times I've used it I've only had the fan on low with the temp setting on the lowest.
Has anyone checked the temp valve? I once had mine on low (high temp) and it didn't really cool at all. I suppose if that was stuck or malfunctioning.
/ 3000 Series A/C Issues #12
I will guarantee that you have gaps in your roof seal. This is a well know problem and if your dealer can't run a DTAC and recognize the symptoms then you need a new dealer. After the fix was made on mine the A/C will make you put a jacket on in 90 degree weather.
I have forwarded all of the things for my dealer to check. Hopefully, when I get back from vacation I will have a cold cab and be proud to own a JD again!
Thanks guys, I'll give an update when I get the unit back.
/ 3000 Series A/C Issues #14
Does your tractor have a sight glass on top of the accumulator? If so look for bubbles going through it. You shouldn't be able to see anything at all. It's common to be undercharged from the factory thee days I've noticed. You wouldn't believe how many new cars and tractors I've had to top off with refrigerant lately. Maybe it's an altitude thing. I don't know. It doesn't take much to effect a 134A system at all.
My new tractor was almost a full pound of 134 low when I got it.
Also, I haven't seen a tractor dealer with a good AC tech yet. I really haven't met another one in a car dealer yet either. I'm sure glad I work on these myself.
the old R12 systems were so nice, they could be slightly over or undercharged, have a little air in the system or whatever and still work good.
Just the smallest amount of air in there on an R134 A system and it's not going to work.
I'm almost willing to bet your mechanics either don't own a recovery machine or probably even a decent vacuume pump. I see a lot of those cheap air powered ones in other guys tool boxes. They are worthless. You're lucky to pull 20 or so inches of vaccume with one. You need one capable of at least 28 to do it right.
I wish you were closer, I'd fix it right for you a whole lot cheaper than any dealer could.
I was a little concerned about finding a good AC tech working at a tractor dealer. The service manager got a little hot when I told him I spoke to another service tech at another JD dealer. But then he is the one that sent me home with it saying thats how it is designed to work.
/ 3000 Series A/C Issues #16
I agree. In fact when my dealer has had the roof off mine he put a new foam seal on the edge. I think he said there is a service bulletin on this. If it is sealed tight it is very cool inside. Great to mow in the 80 to 90 degree heat.
/ 3000 Series A/C Issues #17
Agree, pretty cold on very hot days, so far for me.
Picked up the tractor today and not much change, if any. I tried it for about an hour at 3PM with temperature outside at 96. The air coming out of the vent was able to get down to 77. For the most part it was 78 to 80 degrees.
Dealer said they put almost 40 hours of work into it, the rep told them to replace the compresssor which they did, they said the resealed the top and replaced the expansion valve and tried everything they could think of.
Where to I go from here?
/ 3000 Series A/C Issues #19
Well the "ole" catch 22. Contact John Deere and they will advise you to contact the dealer. I would suggest going to another dealer and trying another tractor like yours on a hot day. This would give you a reference point. I would then by pass the service department and talk to the manager/owner and explain to him that your unit is not performing like other units and ask that it be corrected.
/ 3000 Series A/C Issues #20
Have you tried putting a shut off valve in the heater hose line going to the cab? I installed one on mine. It will shut off any hot water circulating thru the air box on the cab. Got mine at auto parts store for 5/8" line. There is an inline splice on the heater hose at the base of the cab on the left/step side. Clamp off the heater hose with vise grip and remove the splice to insert the valve. I just purchased a 125 hp Case-IH maxuum 125 Pro tractor. They have a shut off valve in the heater hose to the cab. They recommend turning it off to get maxiumum cab cooling. Maybe some hot water is still circulating thru the heater core, even if the valve in the cab is shut off. This maybe a real easy fix for your problem. You could just try clamping off the hose first and then running tractor to see if any difference.
Don't expect to get cold air immediately like a car a/c. The air in the box needs to be cooled before you will notice a decrease in the cab air temp.
Also, try placing a sheet of plastic wrap over the rear cab air filter. It should be getting sucked into the filter. If not, there is a leak in the air box. Make sure your deicer but is turned on in the cab. In the on, "l" position, it seems to cool better.
535 GAL WATER TANK (A68842)
535 GAL WATER TANK...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
NEW HOLLAND T4020 TRACTOR (A65057)
NEW HOLLAND T4020...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
PALLET OF LIFTING STRAPS (A68842)
PALLET OF LIFTING...
2000 Mack DM690S T/A 2,000 Gallon Water Truck (A66736)
2000 Mack DM690S...
