3 pt quick attach
/ 3 pt quick attach #1
m7040
Elite Member
Frederick maryland
Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
Anyone know where I can get a 3pt cat two quick attach bracket so I can mount my pallet forks on the rear of the tractor??
/ 3 pt quick attach #2
I was looking at the exact same thing recently and found ATI has a very nice one. After found out the price with shipping was about $835, I have to think of more reasons and justifications to get it.
/ 3 pt quick attach #3
Harbor Freight has a Cat 1 for $70.00 don't know about a Cat 2. They are made in China, but they seem to fit & work fine.
/ 3 pt quick attach #4
May be I misunderstood the original post. I thought M7040 was referring to type of quick attach that you can mount attachment made for FEL on 3pt hitch.
/ 3 pt quick attach #5
The Harbor Freight QH should be a Cat 1/2, which means you attach it to the tractor with Cat1 pins, but it can lift either Cat 1 (with bushings) or Cat 2 implement pins.
Personally, find a pair of Cat 2 Pat's Easy Change on the lower lift arms and a Cat 2 HTL to be a much more versatile combination than the QH design. A costlier combination, but in my estimation much more convenient (and safe). I think you'd like a HTL on rear fork lift arms.
//greg//
/ 3 pt quick attach #6
Most of these posts are giving the wrong answer. LandPride makes the correst adapter as does ATI as called out above. I believe the original poster wanted to put a SkidSteer QA on the rear of his tractor.
Andy
/ 3 pt quick attach #9
Andy
Actually what I say above is backwards. Sorry
Andy
/ 3 pt quick attach
seems like Bradco is the only one that will allow me to convert from three point to skid steer attachment type implements
/ 3 pt quick attach #12
As t_nguyen noted ....Bradco and ATI.
It is hard to find info on the ATI one..it is not on their website except through the catalog (where the page reference was noted). I too have called ATI previously and found the $800 price a little hard to do right now.
I wish they had a more unique name...every time the subject comes up it seems to draw lots of quick change products that do just the opposite of you want to do!
Good luck
/ 3 pt quick attach
Ordered the one from Bradco today as well as a 73 inch 4-in-one bucket. That way I can hook up the old bucket on the Three point hitch and load it for ballast and still use the 4-in-one bucket on the FEL. Should have it delivered in a couple of weeks.
(4) Lion Hart 265160/18 Tires (A64127)
(4) Lion Hart...
2019 Ram 1500 Pickup Truck (A64556)
2019 Ram 1500...
Gravely Walk Behind Tractor (A65640)
Gravely Walk...
Loader Brackets (A65640)
Loader Brackets...
3 Point Hay Tedder (A65640)
3 Point Hay Tedder...
2022 EZ-GO ELITE...
