3 Pt hitch/PTO different categories?
/ 3 Pt hitch/PTO different categories? #1
Piston
Elite Member
New England
Kubota L4610 Hitachi UH083LC
My father owns a case 275 tractor and it has a category 1 3 pt hitch. I don't really know what that means and what are the differences between them?? i think there are 3 different types right? Can you use category 2 implements with a cat 1 3-pt hitch? or vice versa? Are there any differences in the number of splines on the pto shaft?
im pretty new at this tractor stuff and am having fun learning a lot from you guys.. thanks for all the info! :D
/ 3 Pt hitch/PTO different categories? #2
The Category of the 3 pt hitch is .............? Well, now you have got me thinking :confused:. OK, I am sure someone that knows will post.
I think the Category of the hitch is related to size. For example, my friend's tractor has a Cat I and Cat II. The "balls" in the 3 pt. arms have 2 different size holes in each of them to accept different size pins. You simply rotate the ball to the size, either cat 1 or 2.
The difference in PTO's is the most common 540 RPM and the 1000 RPM. It is not related to the 3 pt hitch. What I mean is you can have 540 RPM in Cat. 1,2,3, or 1000 RPM in all 3.
/ 3 Pt hitch/PTO different categories? #3
Basically the catergories is based on how much HP you have and the more HP you have, the larger the pins gonna be. To make this more confusing, if you have a cat 1 machine, you can also use cat 0 attachaments with sleeve adapters or cat 3 and use cat 2, cat 1 cat 0 but the cat 0 stuff probably will bend like tinfoil with all the HP the machine has.
Category 0 3 Point Hitch
This category is intended for tractors up to 20 Horsepower
Toplink Pins are 5/8" diameter
Lift Arm Pins are 5/8" diameter
Category 1 3 Point Hitch<- - - Most common
This category is intended for tractors 20 to 45 Horsepower
Toplink Pins are 3/4" diameter
Lift Arm Pins are 7/8" diameter
Category 2 3 Point Hitch
This category is intended for tractors 55-95 Horsepower
Toplink Pins are 1" diameter
Lift Arm Pins are 1 1/8" diameter
Category 3 3 Point Hitch
This category is for tractors above 95 Horsepower
Toplink Pins are 1 1/4" diameter
Lift Arm Pins are 1 7/16" diameter
/ 3 Pt hitch/PTO different categories? #5
There is a difference between the PTO shafts between the 540 and 1000 RPM also. You might find an odd side 540 shaft out there on an old tractor.
/ 3 Pt hitch/PTO different categories? #6
Re: PTO speed and splines. Yes, there are SAE standards for PTO shaft size and splines as well. 540 rpm takes a 1-3/8" 13 spline shaft. 1000 rpm is larger and more splines - right now I don't recall.
Thanks for the info, this table from tractordata.com is really helpful, great drawing too for us "less informed" tractor people...
Three-point hitch specifications
Category Hitch pin size Lower hitch spacing Tractor drawbar power
upper link lower links
0 17 mm (5⁄8") 17 mm (5⁄8") 500 mm (20") <15 kW (<20 hp)
1 19 mm (3⁄4") 22.4 mm (7⁄8") 718 mm (26") 15-35 kW (20-45 hp)
2 25.5 mm (1") 28.7 mm (1 1⁄8") 870 mm (32") 30-75 kW (40-100 hp)
3 31.75 mm (1 1⁄4") 37.4 mm (1 7⁄16") 1010 mm (38") 60-168 kW (80-225 hp)
4 45mm (1 3⁄4") 51 mm (2") 1220 mm (46") 135-300 kW (180-400 hp)
Does this mean that although you can get inserts for the hitch pins in order to use a lower category implement, you really can't use that implement because of the lower link arm spacing?
For example if i have a category 2 3 pt hitch, but want to use a log splitter (or anything) that was made for a cat 1 hitch, it won't work because the link spacing on the cat 2 tractor would be 32" whereas the splitter is set up for link arms with 26" spacing?:confused:
Sorry about that table in the above post, didn't paste like i was hoping, it came from the link that Greenwannabe posted....
/ 3 Pt hitch/PTO different categories? #11
...which is part of why I linked to it instead of posting! The forum software reduces all spacing and tabbing to a single space. That can make a table very difficult to read.
In regard to your question on spacing, the lift arms are adjustable, so that part shouldn't be a problem. It will require that you adjust them from the width you use for your other implements, though. You do need to remember that equipment designed for a cat 1 hitch can be very easily pretzled by the power of a tractor with a cat 2 hitch (especially a ground engaging implement), or overwhelmed by the hydraulic lift power of the larger tractor (lifting equipment like a boom). The cat 2 implements are generally built stronger to match the stronger tractor. Best suggestion is to be safe, make sure you are not overstressing cat 1 implements. Good luck.
NEW HOLLAND PULL TYPE ROLL BAR HAY RAKE (A64278)
NEW HOLLAND PULL...
John Deere 4955 Tractor (A66285)
John Deere 4955...
(5) Round Grass Hay Bales (A66408)
(5) Round Grass...
6ft Metal Rooster (A65583)
6ft Metal Rooster...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
2017 Ford F-150 4x4 Pickup Truck (A64556)
2017 Ford F-150...
