3 pt dimentions
/ 3 pt dimentions #1
bbeide
St. Paul, MN
JD 430
Hello,
Long time listener, first time caller......
I'm building a box blade for my tractor and I want to make it a cat 0/ cat 1 sizing.
I've found the pin sizes and spacing of lift arms.
But I can't find the height of the top link above the liftarms at the implement.
How many inches above the liftarm pins is the pin/hole for the top link for a cat 0 and cat 1 3 pt hitch.....
Thanks for your time.
Ben in MN
/ 3 pt dimentions #3
Not sure why, but most manufactures don't seem to follow the ASAE standard for CAT-1 equipment. Fortunately, at least for CAT-2 and larger the standard is followed.
I guess it would be asking too much for everyone to play nice!
/ 3 pt dimentions
Thanks KennyD,
That was the number I was looking for. And this number jogged my memory into thinking the cat 0 height is 12"......
thanks again
Ben
/ 3 pt dimentions #5
Bear in mind the top link is 15" above for the cat 1 guick hitch but for a regular cat 1 it is 18" above. If you build the implement with both 15" and 18" hole spacing you can have the best of both. When using flatbar to make the top link I use a 1 1/4" ODx3/4ID bushing and bolt the two flatbars together with a 3/4" grade 8 bolt and nylock. The bolt bushing and locknut are at 15" above the lower links.
Dont know about the cat 0 never used it.
/ 3 pt dimentions #6
Here is a copy of my 3 pt hitch sheet....hope it helps.
/ 3 pt dimentions #8
I have what you want but it is a PDF document and I can't get it pasted in here.
/ 3 pt dimentions #10
Thanks to all who have posted dimensions!
Unverferth Ripper Stripper (A64126)
Unverferth Ripper...
2023 Giddy Up USA 13ft. S/A Enclosed Cargo Trailer. (A64557)
2023 Giddy Up USA...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A64556)
2022 East...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
46196SFL (A64557)
46196SFL (A64557)
