3 pt dimentions
/ 3 pt dimentions #1
bbeide
St. Paul, MN
JD 430
Hello,
Long time listener, first time caller......
I'm building a box blade for my tractor and I want to make it a cat 0/ cat 1 sizing.
I've found the pin sizes and spacing of lift arms.
But I can't find the height of the top link above the liftarms at the implement.
How many inches above the liftarm pins is the pin/hole for the top link for a cat 0 and cat 1 3 pt hitch.....
Thanks for your time.
Ben in MN
/ 3 pt dimentions #3
Not sure why, but most manufactures don't seem to follow the ASAE standard for CAT-1 equipment. Fortunately, at least for CAT-2 and larger the standard is followed.
I guess it would be asking too much for everyone to play nice!
/ 3 pt dimentions
Thanks KennyD,
That was the number I was looking for. And this number jogged my memory into thinking the cat 0 height is 12"......
thanks again
Ben
/ 3 pt dimentions #5
Bear in mind the top link is 15" above for the cat 1 guick hitch but for a regular cat 1 it is 18" above. If you build the implement with both 15" and 18" hole spacing you can have the best of both. When using flatbar to make the top link I use a 1 1/4" ODx3/4ID bushing and bolt the two flatbars together with a 3/4" grade 8 bolt and nylock. The bolt bushing and locknut are at 15" above the lower links.
Dont know about the cat 0 never used it.
/ 3 pt dimentions #6
Here is a copy of my 3 pt hitch sheet....hope it helps.
/ 3 pt dimentions #8
I have what you want but it is a PDF document and I can't get it pasted in here.
/ 3 pt dimentions #10
Thanks to all who have posted dimensions!
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
NEW HOLLAND PULL TYPE ROLL BAR HAY RAKE (A64278)
NEW HOLLAND PULL...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2025 SDLanch SDLL60 Mini Stand-On Track Loader Skid Steer (A64553)
2025 SDLanch...
KING 3 BAR - 18 SHANK CHISEL PLOW, 3PT (A64278)
KING 3 BAR - 18...
(4) 265/65R18 TIRES & 5 LUG RIMS IN BOXES (A64278)
(4) 265/65R18...
