3 point troubles
/ 3 point troubles #1
BigB3969
Cub cadet sc2450
I have a 2010 Cub cadet Yanmar sc2450. I’m having problems with the three point hitch raising and lowering I recently change the hydraulic fluid and filter. Today I’ve noticed when I get the three-point to go up if I move my front loader the three point starts falling. I also have to raise it very slowly or it acts like I didn’t even try to lift it.I’ve had this tractor for about four months now when I first removed the backhoe I noticed this problem I disassembled the lift valve inspected it for scarring everything inside of it looked good I replaced the O-rings reassembled and everything work good for about three weeks now we’re back to this problem. Any help is much appreciated.
/ 3 point troubles #2
The first thought that came to my mind is bad piston seals on the 3 pt cylinder. Although, when you locked the knob down and the 3pt stayed up, that rules that out.
I'm now leaning towards something wrong on the 3pt valve. Either a check valve that's not fully seating or a pin fell off on the internal linkage for the position control.
/ 3 point troubles
I’m leaning towards the check valve as well because it will drop when I operate the loader
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
1042 (A60430)
1042 (A60430)
2015 Ford Taurus AWD Sedan (A61574)
2015 Ford Taurus...
UNUSED WOLVERINE HYD GRAPPLE BUCKET (A64281)
UNUSED WOLVERINE...
2014 JEEP GRAND CHEROKEE (A64280)
2014 JEEP GRAND...
(1) UNUSED 320/70R24 TIRE W/ 8 LUG RIM (A64280)
(1) UNUSED...
