Quick Hitches 3-POINT QUICK HITCH
/ 3-POINT QUICK HITCH #1
Texas Dodge
Nursery, Texas
Kubota L3400 4WD
Anyone use this one from Harbor Freight??????
Quickly and easily attach and release 3-point implements without leaving your tractor's seat. Designed for tractors up to 45 HP.
Powder coat finish to resist rust
Inside clearance: 26-1/2"
Fits most category 1 tractors
4-position draw pin adjustments
Includes pins and bushings.
Meets ASAE specifications, Draw pin adjustments: 18'', 19'', 20'' and 21'', Overall dimensions: 30" W x 24" H, Weight: 60 lbs.
ITEM 93691-1VGA
$89.99
/ 3-POINT QUICK HITCH #2
Yup!! It works and had mine for a year, welds are a little sloppy. I painted mine green and you can paint it orange!!!!:D
Cool thanks:D :D
/ 3-POINT QUICK HITCH #5
ITEM 93691-1VGA
$89.99
Not yet but I just bought one and it is in my barn ready to put on! I paid 69.99 and used my 15% off one item coupon. The total came to $59.49 plus tax. I could not resist at that price.
P.S. I picked it up at their store so I didn't have to pay shipping!
/ 3-POINT QUICK HITCH #6
Is there a width adjustment on this thing? Doesn't appear so but I have been mistaken before.
We have a Harbor Freight here in town so I will be stopping by after work:D
/ 3-POINT QUICK HITCH #8
I have one but I can only us it on my ballast weight, potato plow and home made hitch. Rear blade is 27 1/2 and even after spreading hf hitch it just won't work. It will fit every thing 26 1/2 wide but not much more.
Brad
/ 3-POINT QUICK HITCH #9
Lower lift hooks are fixed, and usually Cat 2. Buy adapter bushings if you're going to use it with Cat 1 implements. I also strongly recommend buying the optional toplink adapter (Item #29309 for the 93691 Hitch Adapter). There's very little adjustability in that top hook design, so it will be ~$15 well spent.
Far as I know, it's only available if you telephone customer service and ask for it specifically.
//greg//
/ 3-POINT QUICK HITCH #10
I had to bottle jack the bottom of mine to slightly widen it. I also use 2 pieces of flat bar on the top to ensure it fits my implements. That hook just doesn't cut it.
/ 3-POINT QUICK HITCH #11
I have had a Speedco version of that for about 20 years. Tried it once and it fit so few of my attachments that I've never used it since. (said 30 years by accident)
Andy
I'm going to have to do the same. The top hook doesn't work very well with my cutter and BB.:mad:
/ 3-POINT QUICK HITCH #13
I need to find one that would pin on to a cat1 but would hold a cat 2 in the bottom links. the plow I have does not have the 3rd point attached.
/ 3-POINT QUICK HITCH #14
I modified my top hook and it works good now. Originally it wouldn't fit on my shredder or bb ... but by welding some plate on the back of it extending it 1.5" ...it works good. I did buy the adapter as well ..but don't use it now.
/ 3-POINT QUICK HITCH #15
See 'My Harbor Freight Quick Hitch' under the Customization catagory. There are two different models of this hitch. I got the one with an inside clearence of 27.5 verses the other one with 26.5.
Well my adapter bracket came in today and things work so well. No more fighting the lifting arms and no more busted knuckles.:)
/ 3-POINT QUICK HITCH #20
bought it in Nov and haven't even worn the nubs off the tires yet? .... you need seat time.
2017 Mitsubishi Fuso FEC72S Landscape Truck, VIN # JL6BNH1A9HK003132 (A61165)
2017 Mitsubishi...
Pallet of Chain Slings (A61166)
Pallet of Chain...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
JOHN DEERE D110 RIDING LAWN MOWER (A62131)
JOHN DEERE D110...
New/Unused AGT Quick Attach Auger with Three Bits (A61166)
New/Unused AGT...
