Quick Hitches 3-POINT QUICK HITCH
/ 3-POINT QUICK HITCH #21
AndyMA,
I don't know if you've seen our advertisement above, but you should check out the Delta Hook. Our system is adjustable and fits nearly all three point implements. See our website at Delta Hook Homepage or give us a call at 864-404-5614. We can answer any questions you may have.
/ 3-POINT QUICK HITCH #23
I noticed a rubber strap going between some of your hitch pins on your 3-point, do you have problems with the pins falling our? Or is it just a convenient place to keep a strap?
/ 3-POINT QUICK HITCH #24
Kubota's come with a rubber strap that runs from one lift arm to the other. Looks like he has his running vertical because of the HF hitch system.
/ 3-POINT QUICK HITCH #25
I've got a related question. I've had a JD Ballast Box on my 3520 since new and it goes on and off the iMatch without issue. I just pick up a Wallenstein BX42 chipper and I couldn't lift the thing off the pallet it came on without raising it up. Seems I couldn't drop the 3Pt down low enough to get under the attach points. I finally got some more boards under the Wally so I can easily take it on and off but just doesn't seem like it should be that way. Looked in the manual to see if I could adjust the low end height of the rock shaft but nothing. Am I doomed to always have to make "parking stands" for my implements?
/ 3-POINT QUICK HITCH #26
Texas Dodge said:
Weight: 60 lbs.
$89.99
$90 / 60lbs = $1.5/lbs
Considering that the raw material price worldwide is around $0.75/lbs, and that it has forged parts and machined pins, etc. THIS price $90 is very good price. It is EITHER their old price (before the increase of raw material prices) OR made in China.
/ 3-POINT QUICK HITCH #27
And I payed $225 for an imatch that made me modify my boxblade.
/ 3-POINT QUICK HITCH #28
See 'My Harbor Freight Quick Hitch' under the Customization catagory. There are two different models of this hitch. I got the one with an inside clearence of 27.5 verses the other one with 26.5.
This is the secret of these hitches, buy the correct one.
/ 3-POINT QUICK HITCH #29
Or just get Pat's Easy Change that will fit with Any Width of your Attachments. And it's not a secret!
/ 3-POINT QUICK HITCH #30
Pat's appears to be a well made unit and I remember him defending his pricing some time ago in a tread. I have no problem with his price, it was a bit high for me when I could get a HF for $60. The best unit I see out there is the Delta but I have too many implements to even consider that option. It appears one has to dismount the tractor to lock Pat's lower captive pin, I can hook up and never leave the seat.
/ 3-POINT QUICK HITCH #31
Seems like the guys that have the Pats are very loyal and satisfied customers but IMO even if you have to mod your implements to work with the QH it is easier/better not having to get out of the seat at all (for non pto implements anyway).
JB.
/ 3-POINT QUICK HITCH #32
I bit the bullet and got the Delta Hook quick hitch. Paid a bit for a lifetime of convenience and it fits everything. Hook and unhook from the seat in less than 30 seconds. Works every time. After using it for several months I would never ever be without a Delta Hook.
/ 3-POINT QUICK HITCH #33
I must have got the wider one, cause it doesn't fit my (York) Modern Implements 5' york rake, so I haven't been able to use it...I should try to see if HF has the narrower one, but I figure I can also swap out the lift arm pins and buy some adjustable ones for about $5 at Tractor Supply, I'm only 1 or 2 inches short...anyone else try this?
/ 3-POINT QUICK HITCH #34
If the rake was all that did not fit, then I would modify the rake so that it did and let it go at that. When you extend a pin and grab it only by the end you are going to cause a lot of stress on the pin mounting attachment.
Mike
/ 3-POINT QUICK HITCH #35
>>Or just get Pat's Easy Change that will fit with Any Width of your Attachments.<<
Checked them out on their website, and they look pretty good. So, I ordered one from this site and am looking forward to receiving it. I'm getting too old to fight with the conventional 3 PTH set-up!
Tnx,
RUT
The rubber strap keeps the lifting arms from flopping around when there is no implement attached. It hooks both of them together and pulls them toward the center. No need for it now since I have the QH.
/ 3-POINT QUICK HITCH #37
This non-standard hitch thing drives me nuts! Is there supposed to be a standard or not?
I bought a quick hitch at a Ritchie Brothers auction (dirt cheap) that doesn't fit anything I own! I seriously considered that they might have been manufactured wrong or something! Since my snowblower and Harley rock rake are exactly the same, I might just cut the tubing and weld in a piece to fit.
I saw Pats claws at the farm show in Kentucky. Almost bought them, but hate buying things at first sight, without having done research. Plus, they ARE pricy! AND, you still have to struggle with the third point anyway!
Compared to my skid steer attachment implements with a hydraulic coupler, three point hitches are a royal pain and seriously detract from the convenience that a tractor can afford with multiple implements!
/ 3-POINT QUICK HITCH #38
You do have another option, please check out our hitches at CARTERANDSONSLLC.COM. We offer a 100% satisfaction guarantee.
/ 3-POINT QUICK HITCH #39
Well. I put my quick hitch to the saw! Cut it to pieces! My friends in the steel business had some tubing that EXACTLY fit over the existing horizontal tubing. I took some measurements and made it fit my Snow Blower, Harley Pro 8 Rake and a Ditch Bank (Hammer) mower.
And it is SLICK! Albeit the original unit is quite poorly and weakly made! No more hammering out pins under load for this guy!
The thing I particularly don't like is poor visability to the hooks on either side! Vision is totally obscured. I would have built the thing different from the ground up.
Also, I was using my heavy dump trailer and found the quick hitch can get in the way of sharp turns. I have bent one of the hooks (again poor, light duty materials) catching it on the tongue of my trailer. Not only that, but I have to have my hitch down on my JD 6200 because I need every last bit of oil to run a fairly large three stage hoist in my dump wagon. I MUST always remember to raise the hitch again afterwards!
If I had time (which I don't) I would definitely design my own three point (not two) quick hitch. Oh, I also installed a hydraulic top link which seems to allow me much better control and height with my Harley Rake!
/ 3-POINT QUICK HITCH #40
Bought a Speeco Quick Hitch. Altered most of my implements. It is really handy to change from one to another. I use the adapter instead of the hook. It's a great addition to a tractor.:thumbsup:
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
New/Unused Landhonor Quick Attach Grapple Bucket (A65583)
New/Unused...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
