3-Point Hitch 3-point hitch log skidder
   / 3-point hitch log skidder #21
I've used mine for one season so far, works pretty well. There are four grab hooks mounted at the top to hang chokers from.
Sean
   / 3-point hitch log skidder #22
Hey, HarleyScooter that looks like a great setup. What are the wider clevis attactment points on the bucket for. Thanks, Dan
They are for a set of brush forks.
   / 3-point hitch log skidder #23
savageactor7
Do you always run without pins in the drawbar or do you crank the turnbuckles tight so they are not needed?
Yup after bending a turnbuckle because of too much play. I crank the turnbuckles tight so there not needed. The 2 ears below the PTO are pinned.
My son came up with that quick efficient hook up but it's better without the hitch pins.
HarleyScooter, what type/model valves did you by and where did you mount them? Some pix of that set up would sure be appreciated. why not tap into the loader valve fro the grapple valve? Thanks a million.
   / 3-point hitch log skidder #25
Rusty, I used Kubota valves and hooked into where the backhoe hyd lines are. I already had the rear remotes so eight extra feet of hose was a lot cheaper than the extra valve set up, it took a little getting use to but now it is no problem.
   / 3-point hitch log skidder #26
easygo - that is a monster. I like it. You should make 'em and sell 'em
Mf
   / 3-point hitch log skidder #27
Rusty4242, Many of the responses to your original question are reasonable. The concern about stumps preventing backing to the log seems puzzling. Why waste the wood left in a tall stump. We cut all stumps at ground level to eliminate later problems. The other recommendations about jerry rigging: Be certain to PULL the load below your axle, not on the 3 point. If not, flip over is very possible. Any of the chain choker suggestions will work, after lifting the log and setting the choker, then climbing off and releasing the chain/chokers. As it was suggested, if there are numerous logs to be moved, you will find the convenience of never leaving your tractor to hook up, pull out and drop off any log that is within the 22" diameter and that your tractor will handle safely, is well worth the price of the Small Wood Lot Tools equipment.
   / 3-point hitch log skidder #28
To restate SWLT's comment, this is my basic rule:
Lift with the 3pt; pull with the drawbar.
And by drawbar, I mean the one that's permanently under your rear axle.
It's a little more work to make both hitches, but there's never a hint of the front end go skyward.
I usually use a choker chain and and a grab link on the drawbar instead of the 1" rope.
That particular log was to big to get the choker chain around with enough left to reach the drawbar, hence the rope.
This is especially imortant if you try to climb a substantial grade with a similar load.
I have a HF quick hitch that I plan to modify with a blade on the bottom and a beam on the top for holding the tongs. A separate draught chain will be hitched to the drawbar.
   / 3-point hitch log skidder #29
I am going to start building a log skidder for my tractor soon but before I do I figured I would pick your brains a little bit.
I am thinking of building something similar to the picture attached but I am going to add a electric winch
I am not planing to put a hydrolic top link on mine. I guess I could do with out it unless their is a good reason for having it.
Any suggestions on things to add?
   / 3-point hitch log skidder #30
Whenever there is a load being pulled, it must be pulled from the draw bar to insure tractor safety and avoid flip over. The attached photos, appear to place the pulling load above the draw bar which makes the pull unsafe.
Take a look at Small Wood Lot Tools - Timber Maintenance, Pre-commercial Thinning, Firewood, Fuel Reduction Cat 1, 3 Point Log Skidder Attachment. That tool provides hands off hook up, lifting and drop off. Additionally, the pulling load is attached to the tractor's draw bar.
If it is the fun of building your own, then please be sure to attach all pulling loads to the draw bar, NOT the 3 point lift arms or top link. If you want a tool to pull your logs, then visit that web site and you will likely save some money compared to the system shown in the your attached photos.
2014 Dodge Charger Passenger Car, VIN # 2C3CDXAT8EH223963 (A57453)
2014 Dodge Charger...
20ft Driveway Entrance Gate w/ Tree of Life Design (A57454)
20ft Driveway...
Forklift (A56857)
Forklift (A56857)
2020 DRAGON ESP...
2016 Kia Optima Sedan (A56859)
2016 Kia Optima...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59575)
2017 ISUZU NPR 18...
