2810 Hydro surge
/ 2810 Hydro surge #1
dieselsmoke1
Platinum Member
Eastern North Carolina
Mahindra 2810HST
My piece has always eased into motion silky smooth from a dead stop. Noticed today that if there was no resistance it wants to surge slightly when it starts motion. Any resistance and the surge is undetectable. Not a big problem but a different behavior. All other functions seem normal. Anyone got thoughts on this?
I've got about 100 hrs on the tranny oil so I figured to change it and see if that helps. What tranny oil are you guys running?
Thanks
/ 2810 Hydro surge #2
Haven't noticed what you're experiencing. I'm at about 340hrs and a little over 300hrs on Sams Club hydro fluid. Going to change to PermaTran fluid from the local dealer shortly.
/ 2810 Hydro surge #3
I had thought about saying something about using Permatran in that model of Mahindra before because the tranny and rear axle is the basically the same as the larger size MF compact even though the pumps are different. I didn't because I thought some might take it some way other than the way it was meant.
/ 2810 Hydro surge
PermaTran is a good thought. Used lots back in the MF days. Probably more similar (light and clear) to what came in it than what I've got in the tranny now. Seems to look a tad heavier and has a greenish tint.
Thanks
/ 2810 Hydro surge #5
I'll take any suggestion you have, anytime!
You weighed in on a recent thread I started about hydro fluid and I'm taking your advice and going with permatran. The local Massey dealer is new to Mahindra and has been out of the 5gal pails, should be in soon. I've had good results with the cheap fluid but, why was I going the cheap route on this? No more, going with the good stuff.
/ 2810 Hydro surge #6
I really think that you will be happy with it. Before the synthetics showed up on the market, I thought that Permatran was the best fluid on the market. I don't know how it compares to the synthetics now that we have them.
/ 2810 Hydro surge
After buying 10 gal. of PermaTran and a filter, I found the cause of the surge. 1/2" wrench and 2 minutes to fix, good as new. Oh well, I wanted to change to PermaTran anyway....
Look up in the tranny cavity where the filter is, see the actuator on the starboard side of the tranny near the filter base and the rod that connects to it. Follow the rod to the opposite end where it engages the dual pedal rocker cam. The nut that secures the rod end eye bolt to pedal mechanism was loose, about 3 rounds. Apparently if there is no resistance to movement, when the tranny gets a taste of flow, it grabs all it can (i.e.takes all the lost motion out of the linkage in the gotta go direction).
Not often you can solve a tranny issue with a 1/2" wrench and a beer. Consider myself lucky.
/ 2810 Hydro surge #8
Thanks for the follow-up, I'll be checking mine.
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2004 Chevrolet Silverado 1500 4x4 Pickup Truck (A61573)
2004 Chevrolet...
SCAN TO RECEIVE TEXT UPDATES (A64279)
SCAN TO RECEIVE...
2019 KAUFMAN 46' STEP DECK TRAILER (A64280)
2019 KAUFMAN 46'...
2004 John Deere 4720 (A60462)
2004 John Deere...
6 Band Wooden Barrel (A61574)
6 Band Wooden...
