2555 running cold
   / 2555 running cold #1
Glrret
Somerset County, Maine
Mahindra 2555 Shuttle
Well I'm not looking forward to another cold running tractor this winter. My 2555 runs really cold, last winter the needle on the temp gauge never moved off cold, even after running it for hours. I took it to the dealer and they did some sort of software upgrade and now the gauge will go up the the normal operating temp on the gauge but the engine is still cold and the heater blows cold air.
I seem to remember last winter someone was talking about a flow limiter or some way to get the engine to warm up. Was there ever an actual solution put into production?
   / 2555 running cold #2
That mod might be necessary. I recall seeing that thread. I would definately try the following first. Simple and effective:
In the great white north we just cover the rad with something. Usually cardboard or canvas. I just put the cardboard on my Kioti a few days ago. It has a square hole in the middle (in the middle to balance the cooling fan suction. Just cause my Dad told me that a gazillion years ago). It covers more than 75% of the rad (100% minus the hole).Additionally, engine compartments sometimes get tarped with canvas to more fully enclose the space. Lower-front and sides, usually.This will keep the heat in. I should probably make canvases for the Kioti too. The cardboard is a major improvement, but not quite enough at more than 25-30 below.
Routine. Standard procedure for a Canuck.
Simple. Effective. Inexpensive.
   / 2555 running cold #3
Yep.....X2
   / 2555 running cold #4
It used to be common, and might still be, to have tractor trailer rigs with covers snapped over the grills. They were designed so you could open a corner or two if it wasn't super frigid out.
   / 2555 running cold
I've been looking all over the Internet for a grill cover, winter front, engine wrap, anything to help the engine to warm up.
I tried blocking the radiator last winter and it didn't really help.
What I would really like to find is an insulated wrap around hood and grill cover that has a way to open the grill area as desired what temperatures rise above the lower teens.
   / 2555 running cold #7
You'll likely have to make your own.
   / 2555 running cold #8
Just a thought....check and see if your heater lines have shut off valves, they will put them in so you can shut off heat in the summer. Hopefully a simple fix!
   / 2555 running cold
I wonder were the valve would be, any ideas were I should start to look?
   / 2555 running cold #10
Usually under the hood on the lines going to the cab heater
2012 UTILITY VS2DX 53FT DRY VAN TRAILER (A52141)
2012 UTILITY VS2DX...
Gehl 1870 Round Baler (A50514)
Gehl 1870 Round...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52128)
2021 John Deere...
vergenes (A50657)
vergenes (A50657)
