24x24 garage question
   / 24x24 garage question #1
HammA5690
Upstate , NY
Jd 2520
I have a 24x24 concrete pad that a house previously sat on before I purchased the property. I have not yet checked if it has a 3 ft footing around the outer edges but IF it does I was wondering 2 things.
In New York can you :
- build a garage over an existing pad without permits because there is part of an existing building already in place?
- would I be able to bolt a sill plate or 4x4 supports to the concrete pad and expect it to hold up the building?
I would much rather bolt a sill board down and stick build it or bolt the 4x4 to concrete metal adapters ad pole barn build it than set footings for the poles around the perimeter of the pad. Any help would be great, Ill most likely be asking the town code enforcer the same questions soon.
Thanks in advance!
   / 24x24 garage question #2
You are going to have to check with your local building codes to see what they would require... what inspections you will need to do.
If there was a house there before it should be fine to bolt the sill plate to the concrete structurally and support the garage. You would have to get the advice from a structural engineer to determine if the pad can support the pole barn posts though.
   / 24x24 garage question #3
I would construct it like I would any new garage on a concrete slab.
Bolt a 2x4 or 2x6 pressure treated sill plate down with 1/2" x3 1/2" red heads, then frame that bad boy up. It's upto you if you order trusses or build your own roofing system with a main 2x6 span across the center and cut individual 2x6's to make up the rafters. I usually do it the old school way because trusses + a truck to deliver them runs pretty high usually.
   / 24x24 garage question #4
Wouldn't fly here......or maybe it would given the right wind :laughing:
Check with YOUR building dept.
   / 24x24 garage question #5
Yeah, depends on what the local inspector thinks, along with codes.
The last house I built was on a brick foundation and had to have L bolts that went down 8". My mom's house is on slab and is simply nailed down with 3 1/2" ramset nails and bolted at every corner.
When i closed my carport in as a garage I ramsetted the sill down to the brick foundation on the side, but used redheads at the sill where the garage door is just in case someone hits the door opening with a car one day.
I'm clearing trees out myself now in hopes of building a 24x30 pole barn sometime next year with a gravel floor and roll up door.
   / 24x24 garage question #6
Where we live in NW PA, the code requires a permit only if the building is over 1000 sq.ft.
   / 24x24 garage question #7
I would check in with the local building inspection department. They have a very nasty trump card when when somthing is built without a permit even if it is built perfect ( TEAR IT DOWN ) .
The only newer code change to a garage in ( Ontario ) on a slab is a 8 " high cement block wall to keep the bottom sill clear off the ground. I am not sure about L bolts into slab through the block to anchor the sill.
Craig Clayton
   / 24x24 garage question #8
I doubt it. I would start with two rows of block.
   / 24x24 garage question #9
I had a follow up thought about dealing with the insurance company. I have spent several hours watching Judge Judy and looking at the law ( U.S. / Can. ).
If your unregistered garage ever burned to the ground because of a fire and I was them I would take you to court and claim that according to the State records there is only an empty slab on your property. And that they have no proof of your 20 - 40 th dollar claim.
Craig Clayton
   / 24x24 garage question #10
Interesting thoughts. If you were replacing something with same size and shape, like a door, window etc no permit needed. Building a garage same size and shape as house but a different usage will most likely require a permit. I think if the garage is being built attached to house might require concrete blocks, but standalone might be ok stick built the way you want it, but a permit is still needed due to its a totally different structure. IF you have the original plans of the foundation and it would pass your town codes for "footings" for a garage then you may have saved yourself alot of money. I am going to say your chances of being able to reuse the concrete pad for a garage use are 50/50.
If worse comes to worse, you could dig new footing on the outside of the pad for the walls and underpin it to old pad to satisfy code inspector.
   / 24x24 garage question #11
You will have to ask the code enforcement dept. in your town.
   / 24x24 garage question #12
I have been building garages and new homes for 42 years and live in Steuben County N.Y. You need to meet with the Building Code Officer for your Town. Local building codes superceed all national building codes. I have found that every town code enforcement officer has different opinions, and he or she is the one you have to answer to. I could tell you what I think is best, but I'm not the one you have to answer to. Be sure to check with them before you plan anything. Clayton Simonds, General Contractor.
   / 24x24 garage question #13
Thanks in advance!
if it's 30 second check with a shovel to see if you have a floating slab or a footing. regardless of what you can get away with - legally or not - i don't think i'd want to attempt a pole barn on a floating slab. a floating slab is fine for a typically framed structure where your load is distributed via studs at every 16-24 inches through a sill plate to the slab, but if you put posts every 8 feet or so, that's a lot of weight on one small spot - especially in the north where frost lives.
other than that, check with your local building inspector's office for the do's and dont's. i've traveled through upstate new york enough times, and from what i can see, if you're in a rural area then you probably have fairly reasonable codes, but if you are within some city limits things may require more paperwork and effort.
   / 24x24 garage question #14
ours is 200 square feet before permit is required... sounds kind of restrictive, but it is what it is i guess.
   / 24x24 garage question #15
Thanks in advance!
If there's no neighbors just build it ;)
   / 24x24 garage question #16
We're lucky. Around here all that's needed is a state permit for a septic system (for a house). Otherwise you are free to build almost anything.
   / 24x24 garage question #17
Here in Upstate (central NY Owego not Oswego) we need a permit for ANY building project. Electrical inspection before final CA is given. Where are you in Upstate NY?
   / 24x24 garage question #18
Use a floor that was poured for a house first level or a basement for a garage? Traditionally, the heaviest thing a home house floor had to support was probably a 200 lb man but a garage floor has a car sitting on top. That old living room floor might be poured of thinset. Possible it's not even 4" thick and not a stitch of rerod. I'll bet it is already cracked. The mateiels for your garage (lumber) cost to0 much to just throw on top of something less than a new reinforced foundation and floor. Do it like you want it to stay around for a while.
Fasten pole barn uprights to that old floor thing? Not for my pole barn. Those 6X6"'poles are designed to go to the bottom of a four foot hole and get packed backfill to anchor them securely. Who knows what your floor is composed of. Don't cut any corners like that and you will be glad you did it right from the get go.
rimshot
   / 24x24 garage question #19
I hate it for ya, but check with building inspector. Reason is you may get away with it till the tax people show up for "reassessment"They'll impose a fine an back taxes.
Take a shovel an see how deep the footing goes.
My county is the last one in Ga. with no building inspector!Life is great, but we do have to declare anything we build for tax reasons.If you don't they fine you an back taxes back to last assessment year.
Most of the time the long way is the easy way.
Army Grunt
   / 24x24 garage question #20
In Rideau Lakes Township in Ontario I discovered a loophole which allows a building to be erected on a slab without an engineer's drawings if the slab does not exceed 580 square feet.
That's your 24 X 24. It might be worthwhile to check your building code carefully.
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A61306)
1992 Talbert 70...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
2008 HINO 26FT NON CDL BOX TRUCK (A59905)
2008 HINO 26FT NON...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
RUT E-TS-36-36" HYD TREE SLAYER MOWER (A60429)
RUT E-TS-36-36"...
2021 Kubota SVL75-2 Track Loader (A61306)
2021 Kubota...
