24x24 garage question
   / 24x24 garage question #21
I think the consistent good advice here is to talk to the local inspector. Most of them are good guys unless you approach them like a jerk.
As far as the basic approach, I would definitely dig to check the footing and also drill a few small holes in the middle of the slab to check the thickness and make sure it's appropriate for a garage. It would be bad news to put in the garage and then have the slab crack.
I'm not sure why it would be an advantage to go with poles for a garage on and existing slab. I would drill in anchor bolts and build up normal 2x4 stud walls. Unless you are going over 10 foot tall I think it would be easier. Stud walls give you a lot more options on interior and exterior finish, heating, etc.
CATERPILLAR 72" HANG-ON WHEEL LOADER FORKS (A60429)
CATERPILLAR 72"...
2013 Toyota Corolla (A59231)
2013 Toyota...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2007 JCB 3CX BACKHOE (A60429)
2007 JCB 3CX...
FORD 3000 TRACTOR (A60430)
FORD 3000 TRACTOR...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
