Sickle Bar # 22 int sickle mower?
/ # 22 int sickle mower? #1
Sheepdr
fernley,nv
4330 kabota
I rebuilt a # 22 or 24 int sickle mower. It works great and cuts faster than a kauhn mower I have. Except I get a lot of build up of grass at the last section on the outer toe. I am almost to the conclusion that my sickle bar is to short by 1 section. On my kauhn mower there is a section that goes out past the guards when fully extended. I have 2 sickle bars for the int and both are the same length. Should I cut the sickle bar and add enough to get another section? These bars have 28 sections on them. I tried removing the last section but it didn't help. I also saw in here some place something about timing but can't find it again. I can't see how you could change the timing. Maybe shorten the pitman arm.
I would really appreciate any ideas you might have.
Sheepdr
/ # 22 int sickle mower? #2
/ # 22 int sickle mower? #3
I agree with DJ54 you need to install a section & 1/2 on the very end of the sickle. I sold those back in the 60's through the late 80's when I worked in a JD parts dept.
Hey thanks. You wouldn't have an idea which one it might be would you?
/ # 22 int sickle mower? #5
You'll need to match up with the sections on your mower. Top serrated, bottom serrated, smoth, etc. If you would decide to order from Webb's, give them a call, and tell them what you have. I'm sure they can fix you right up. I get my knives for my old IH 990 MoCo there. Very good to deal with.
2014 CASE IH Magnum 340 (A63111)
2014 CASE IH...
3PT BOG HARROW (A63291)
3PT BOG HARROW...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
2016 WILDWOOD TRAVEL TRAILER (A63569)
2016 WILDWOOD...
2000 FREIGHTLINER 3-AXLE BOBTAIL VACUUM TRUCK(INOPERABLE) (A63569)
2000 FREIGHTLINER...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
