Sickle Bar # 22 int sickle mower?
/ # 22 int sickle mower? #1
Sheepdr
fernley,nv
4330 kabota
I rebuilt a # 22 or 24 int sickle mower. It works great and cuts faster than a kauhn mower I have. Except I get a lot of build up of grass at the last section on the outer toe. I am almost to the conclusion that my sickle bar is to short by 1 section. On my kauhn mower there is a section that goes out past the guards when fully extended. I have 2 sickle bars for the int and both are the same length. Should I cut the sickle bar and add enough to get another section? These bars have 28 sections on them. I tried removing the last section but it didn't help. I also saw in here some place something about timing but can't find it again. I can't see how you could change the timing. Maybe shorten the pitman arm.
I would really appreciate any ideas you might have.
Sheepdr
/ # 22 int sickle mower? #2
/ # 22 int sickle mower? #3
I agree with DJ54 you need to install a section & 1/2 on the very end of the sickle. I sold those back in the 60's through the late 80's when I worked in a JD parts dept.
Hey thanks. You wouldn't have an idea which one it might be would you?
/ # 22 int sickle mower? #5
You'll need to match up with the sections on your mower. Top serrated, bottom serrated, smoth, etc. If you would decide to order from Webb's, give them a call, and tell them what you have. I'm sure they can fix you right up. I get my knives for my old IH 990 MoCo there. Very good to deal with.
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
2016 FORD TRANSIT 350 PASSENGER VAN (A66091)
2016 FORD TRANSIT...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
