Sheepdr
Bronze Member
I rebuilt a # 22 or 24 int sickle mower. It works great and cuts faster than a kauhn mower I have. Except I get a lot of build up of grass at the last section on the outer toe. I am almost to the conclusion that my sickle bar is to short by 1 section. On my kauhn mower there is a section that goes out past the guards when fully extended. I have 2 sickle bars for the int and both are the same length. Should I cut the sickle bar and add enough to get another section? These bars have 28 sections on them. I tried removing the last section but it didn't help. I also saw in here some place something about timing but can't find it again. I can't see how you could change the timing. Maybe shorten the pitman arm.
I would really appreciate any ideas you might have.
Sheepdr
Sheepdr
