2022 MT357 Cab Hitch
/ 2022 MT357 Cab Hitch #1
mswvette
New Holland TC33D
The specs say Cat 2 hitch but the top link only has a 3/4" pin, the lift arms are 1 1/8", is this typical?
/ 2022 MT357 Cab Hitch #3
That should be a 1" pin on the top link. The specs for that tractor do indicate a cat 2 hitch. What is the pin size where the top link hooks to the tractor?
/ 2022 MT357 Cab Hitch #4
Pin size of the top link on the tractor side is 3/4" and, as you stated, 1" on the implement side. Seems to be pretty standard for this size tractor as my 50 year old JD 2020 has the same size pins on the top link. Lift arms pins are the normal CAT II 1 1/8". Guess this keeps you installing the top link in the same direction all the time.
/ 2022 MT357 Cab Hitch #5
I have the same deal on my MT352 which is a Cat II 3pt hitch. I use cat I implements so use the top link as is and use bushings on the hitch arms. If you have cat II implements then you need a bushing for the top link. I keep several extra in the cab. I loose them frequently - forget they are there when taking off implements,
/ 2022 MT357 Cab Hitch #6
They use CAT 1 on the tractor side and CAT 2 on the implement side. So your top link should be 3/4" for the tractor side pin and 1" at the implement side. Sounds like the factory may have put the wrong top link on but the dealership should be able to fix that pretty easy.
John Deere 50 (A60462)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
2016 International WorkStar 7400 T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2016 International...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
