2022 MT357 Cab Hitch
   / 2022 MT357 Cab Hitch #1
mswvette
New Holland TC33D
The specs say Cat 2 hitch but the top link only has a 3/4" pin, the lift arms are 1 1/8", is this typical?
   / 2022 MT357 Cab Hitch #3
That should be a 1" pin on the top link. The specs for that tractor do indicate a cat 2 hitch. What is the pin size where the top link hooks to the tractor?
   / 2022 MT357 Cab Hitch #4
Pin size of the top link on the tractor side is 3/4" and, as you stated, 1" on the implement side. Seems to be pretty standard for this size tractor as my 50 year old JD 2020 has the same size pins on the top link. Lift arms pins are the normal CAT II 1 1/8". Guess this keeps you installing the top link in the same direction all the time.
   / 2022 MT357 Cab Hitch #5
I have the same deal on my MT352 which is a Cat II 3pt hitch. I use cat I implements so use the top link as is and use bushings on the hitch arms. If you have cat II implements then you need a bushing for the top link. I keep several extra in the cab. I loose them frequently - forget they are there when taking off implements,
   / 2022 MT357 Cab Hitch #6
They use CAT 1 on the tractor side and CAT 2 on the implement side. So your top link should be 3/4" for the tractor side pin and 1" at the implement side. Sounds like the factory may have put the wrong top link on but the dealership should be able to fix that pretty easy.
2014 Ford Explorer AWD SUV (A48082)
2014 Ford Explorer...
2014 FREIGHTLINER M2 TANDEM AXLE FLATBED (A45678)
2014 FREIGHTLINER...
2004 GMC C6 FLATBED (A45678)
2004 GMC C6...
2010 Chevrolet Impala Sedan (A46684)
2010 Chevrolet...
24ft Corral Panels (A49251)
24ft Corral Panels...
New Holland L170 Skid Steer Loader (A49251)
New Holland L170...
